%Error: AP: should not have same Primary and Secondary controller name
DATHOZ
This is a weird error while trying to reverse AP on 9800 primary and secondary server
Here is an example
wlc-ha-4# show ap name ap-0064-2-541 config general | inc Controller
Primary Cisco Controller Name : wlc-ha-4
Primary Cisco Controller IP Address : 172.x.x.y
Secondary Cisco Controller Name : wlc-ha-5
Secondary Cisco Controller IP Address : 172.x.x.x
Tertiary Cisco Controller Name : Not Configured
Tertiary Cisco Controller IP Address : 0.0.0.0
wlc-ha-4#ap name ap-0064-2-541 controller primary wlc-ha-5 172.x.x.y
% Error: AP: ap-0064-2-541 should not have same Primary and Secondary controller name
wlc-ha-4#ap name ap-0064-2-541 controller secondary wlc-ha-4 172.x.x.x
% Error: AP: ap-0064-2-541 should not have same Secondary and Primary controller name
I tried changing to a diff name and it still does not work
wlc-ha-4# ap name ap-0064-2-541 controller primary wlc5 172.x.x.y
% Error: f4db.e6fb.5120Primary : Primary, Secondary and Tertiary IP address must be unique
wlc-ha-4#ap name ap-0064-2-541 controller secondary wlc4 172.x.x.x
% Error: f4db.e6fb.5120Secondary : Primary, Secondary and Tertiary IP address must be unique
Leo Laohoo
  1. Configure the secondary controller details FIRST. Enter a fictitious detail.
  2. Enter the REAL primary controller details next.
  3. Enter the REAL secondary controller details last.
Leo Laohoo
ammahend
Try Remove the secondary controller config, then change primary controller config then add secondary controller.
from cli try this command to remove
config ap secondary-base ' ' APHOSTNAME 0.0.0.0
Note that between the quotes there is 1 space.
If it does not work try GUI.
secondly if you have prime, you can easily do it with a lightweight AP config template.
-hope this helps-
