error connection between vwlc and AP
zineb
Visitor
I am new to Wireless network and have been tasked with setting v WLC Cisco and AIR-CAP702I-I-K9. I followed some guides to configure the WLC, but however the APs are not joining the controller. with console cable connected to the AP i get the following;
*Mar  1 00:01:02.879: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER
*Mar  1 00:01:02.883: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'Cisco_17:1d:20'running version 7.3.101.0 is rejected.
*Mar  1 00:01:02.883: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar  1 00:01:02.883: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Mar  1 00:01:02.883: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Mar  1 00:01:02.883: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 10.0.0.1
*Mar  1 00:01:02.887: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'Cisco_17:1d:20'running version 7.3.101.0 is rejected.
*Mar  1 00:01:02.887: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar  1 00:01:02.887: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (255.255.255.255)
Please can you help me it is very urgent
14 Replies 14
Leo Laohoo
The vWLC is running the wrong or outdated firmware.  For a AP702, the vWLC should be running a minimum of 7.6.X formware.
I would, however, recommend you run the latest 7.6.130.X as this is a stable version and 7.5.X is classified as "deferred".
That's right!!
I am getting the same error ,as you can see my time is correct , I can ping the AP from WLC
any idea ? much appreciated
(Cisco Controller) >show time
Time............................................. Tue Dec 23 22:39:49 2014
Timezone delta................................... 0:0
Timezone location................................
NTP Servers
    NTP Polling Interval.........................     86400
     Index     NTP Key Index                  NTP Server                  NTP Msg Auth Status
       1              0                               119.252.27.44       AUTH DISABLED
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.6.110.0
RTOS Version..................................... 7.6.110.0
Bootloader Version............................... 7.6.110.0
Emergency Image Version.......................... 7.6.110.0
Build Type....................................... DATA + WPS
System Name...................................... vWLC1
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1631
IP Address....................................... 192.168.0.202
System Up Time................................... 0 days 0 hrs 43 mins 32 secs
System Timezone Location.........................
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... AU  - Australia
--More-- or (q)uit
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 2
Number of Active Clients......................... 0
Burned-in MAC Address............................ 00:0C:29:29:32:68
Maximum number of APs supported.................. 200
################Log from AP ##############################
*Dec 23 22:41:16.007: %CAPWAP-3-ERRORLOG: Certificate verification failed!
*Dec 23 22:41:16.007: DTLS_CLIENT_ERROR: ../capwap/capwap_wtp_dtls.c:348 Certificate verified failed!
*Dec 23 22:41:16.007: %DTLS-4-BAD_CERT: Certificate verification failed. Peer IP: 192.168.0.202
*Dec 23 22:41:16.007: %DTLS-5-SEND_ALERT: Send FATAL : Bad certificate Alert to 192.168.0.202:5246
*Dec 23 22:41:16.007: %DTLS-3-BAD_RECORD: Erroneous record received from 192.168.0.202: Malformed Certificate
*Dec 23 22:41:16.007: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 192.168.0.202:5246
*Dec 23 22:41:16.007: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 3 combination.
I try with another  Access Point , i get the following with console cable connected to the AP
Can you help me please
*Jul 23 13:25:09.974: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Nov 30 06:31:54.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.0.0.1 peer_port: 5246Peer certificate verification failed 000B
*Nov 30 06:31:55.032: %CAPWAP-3-ERRORLOG: Certificate verification failed!
*Nov 30 06:31:55.032: DTLS_CLIENT_ERROR: ../capwap/base_capwap/capwap/base_capwap_wtp_dtls.c:337 Certificate verified failed!
*Nov 30 06:31:55.032: %DTLS-5-SEND_ALERT: Send FATAL : Bad certificate Alert to 10.0.0.1:5246
*Nov 30 06:31:55.033: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.0.0.1:5246
*Nov 30 06:31:55.033: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 3 combination.
There is certification verification failed & hence AP not registered.
Check in your vWLC to see correct time "show time" output verify this.
Rasika
*** Pls rate all useful responses ****
Can you post the following outputs:
1.  WLC:  sh sysinfo;
2.  WLC:  sh time;
3.  AP:  sh version
hi
Outputs are :
Product Version.................................. 7.3.101.0
RTOS Version..................................... 7.3.101.0
Bootloader Version............................... 7.3.101.0
Emergency Image Version.......................... 7.3.101.0
System Name...................................... Cisco_17:1d:20
IP Address....................................... 10.0.0.1
System Up Time................................... 1 days 3 hrs 59 mins 19 secs
System Timezone Location......................... (GMT +1:00) Amsterdam, Berlin, Rome, Vienna
Configured Country............................... TN  - Tunisia
--More-- or (q)uit
Number of WLANs.................................. 1
Burned-in MAC Address............................ 00:0C:29:17:1D:20
Time............................................. Fri Dec 12 15:50:48 2014
Timezone location................................ (GMT +1:00) Amsterdam, Berlin, Rome, Vienna
NTP Servers
AP7c69.f670.d1a9#show version
Cisco IOS Software, C1140 Software (C1140-K9W8-M), Version 12.4(25e)JA1, RELEASE        SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Wed 30-May-12 04:06 by prod_rel_team
ROM: Bootstrap program is C1140 boot loader
BOOTLDR: C1140 Boot Loader (C1140-BOOT-M) Version 12.4(23c)JA6, RELEASE SOFTWARE        (fc1)
AP7c69.f670.d1a9 uptime is 15 minutes
System image file is "flash:/c1140-k9w8-mx.124-25e.JA1/c1140-k9w8-mx.124-25e.JA1        "
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-LAP1141N-E-K9    (PowerPC405ex) processor (revision B0) with 65526K/65        536K bytes of memory.
Processor board ID FCZ1743P23U
PowerPC405ex CPU at 586Mhz, revision number 0x147E
Last reset from power-on
LWAPP image version 7.2.110.0
1 Gigabit Ethernet interface
1 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 7C:69:F6:70:D1:A9
Part Number                          : 73-12836-06
PCA Assembly Number                  : 800-33767-06
PCA Revision Number                  : A0
PCB Serial Number                    : FOC172964DZ
Top Assembly Part Number             : 800-33776-05
Top Assembly Serial Number           : FCZ1743P23U
Top Revision Number                  : A0
Product/Model Number                 : AIR-LAP1141N-E-K9
Configuration register is 0xF
As we can see WLC does not have correct time
Sync WLC to a NTP server to get the correct time. Then AP should register
Rasika
**** Pls rate all useful responses ***
Can you suggest an NTP server on windows 7
thanks
You can use public NTP server that can found here
http://www.pool.ntp.org/en/
If you have a router as internet gateway, sync that device to one of this public NTP server & then all your internal device to sync with your router as NTP.
See this post for basics of NTP functionality
http://mrncciew.com/2013/04/28/ntp-basics/
*** Pls do not forget to rate our responses if you find them useful ****
Rasika
So if I correctly understand , the problem is the result of the missing of the synchronization between AP and vWLC although I have set the time on the vWLC and I verified that the PA has the same time.
Is it mandatory to have an NTP server?
Best regards
It is mandatory to have the correct time & sync to NTP is the best way to do it. You can manually set the time, but accuracy will be not that high.  Also when you have RADIUS servers/ AD /MSE/ Prime integrated, every thing should sync to a common NTP to get them work, manual clock setting is not practical in those scenarios.
Try to set WLC time manually & see your APs get registered.
Rasika
USUALLY if I manually adjusts the time, the cli AP it will not display the error
but every time I manually adjusts the time it shows the same error
I agree with Rasika.
The AP won't join the controller because the WLC's time & date are incorrect.
Windows OS do NOT adhere to NTP/SNTP standard.  Windows OS will work well as an NTP client but never as an NTP server.
The best method to get NTP is to use public NTP pool found on the internet.
