Error Install package wifi (Embedded Wireless wifi) in the fabric doma
You can use two Embedded Wireless Controller in the two switch Catalyst different Edge nodes (C9300) (version 17.3.3) and package wifi (C9800-SW-iosxe-wlc.17.03.03.SPA) on my  server DNA Center  version (2.2.2.6)
I installed package wifi in the edge Node 1 with server dna center is success
but in the seconde Edge node 2 with server dna center is show me error
Tech note: in the same Fabric domaine
Can you confirm the following:
Fabric enabled?
Same Fabric
Same Site/ floor
Two Separate 9300 Switches
What error is it showing?
I take it you are looking to do HA here?
*****Help out other by using the rating system and marking answered questions as "Answered"*****
Yes fabric domaine enable, in the same fabric domaine. Same building
Embedded wireless in the edges node c9300 floor 1
And embedded wireless in the edges node floor 2 c9300, the second embedded wireless not installed show me error provisions
And need solution about ha
Télécharger Outlook pour Android
