Error message help: webauthRedirect Parse Error
Sean Graham
Visitor
I'm seeing these messages show up in the Message Log over and over. I can't find much info on them.
*webauthRedirect: Mar 05 13:30:53.756: %EMWEB-3-PARSE_ERROR: webauth_redirect.c:954 parse error after reading. bytes parsed = 0 and bytes read = 128
*webauthRedirect: Mar 05 13:30:53.756: %EMWEB-3-PARSE_ERROR: webauth_redirect.c:954 parse error after reading. bytes parsed = 0 and bytes read = 58
*webauthRedirect: Mar 05 13:30:53.756: %LOG-3-Q_IND: webauth_redirect.c:954 parse error after reading. bytes parsed = 0 and bytes read = 128[...It occurred 3 times.!]
*webauthRedirect: Mar 05 13:30:53.734: %EMWEB-3-PARSE_ERROR: webauth_redirect.c:954 parse error after reading. bytes parsed = 0 and bytes read = 128
*webauthRedirect: Mar 05 13:30:53.733: %EMWEB-3-REQUEST_IS_NOT_GET_ERROR: webauth_redirect.c:1029 Invalid request not GET on client socket 75
*webauthRedirect: Mar 05 13:30:53.725: %EMWEB-3-PARSE_ERROR: webauth_redirect.c:954 parse error after reading. bytes parsed = 0 and bytes read = 58
Its not causing any problems that I can see. The web authorization for our guest network is still working fine.
My WLC is a 5508 running 7.2.103.0.
Christian S.
Level 2
Level 2
Hi Sean,
there's a bug-id for this issue:
CSCtx68753 - HTTP parser errors
Chris
Christian S.
Level 2
Level 2
Hi Sean,
Chris
Hi, I have same messages if using CWA with ISE Guest portal. Also working fine for Windows7, but I have problem with iPhone/iPad - only blank white screen www.apple.com. Is this bug related to my problem?
Ladislav
