Error when disable 802.11a radio
Thiago Gandara
Hello, i need a help, when i try disable the 802.11a radio the attached error appears.
Thanks.
Thiago.
Glad you got it working!
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Scott Fella
Try to set the TX power level fist on the AP hit apply and then disable the radio.
Scott
-Scott
I realize that the  "802.11a Power Status" was Automatic, then i change to Disable and put the number 1 on Current TX Level, and works fine.
Thanks.
Scott
-Scott
