EWC 9115 with 2700 access point do not join controller
BosePhones
I have some problems getting my 2700 access point to join my 9115 ewc running 17.9.3 software. I tried using a C9800-CL on a esxi and the access point got the correct software and joined that controller.
FW is open and connectivity to tftp server is working. I have setup the tftp config on the ewc 9115 ap:
wireless profile image-download default
description "default image download profile"
image-download-mode tftp
tftp-image-path /
tftp-image-server 10.0.10.115
I have downloaded all three files for the 2700 ap here: https://software.cisco.com/download/home/286256843/type/280775090/release/15.3.3-JPN2
I unzipped the tar file and placed the content like this. What am I missing here?
I followed the documentation of what software is correct for 2700 ap.
On the controller side these messages come all the time:
*Aug 29 20:02:13.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.0.20.101 peer_port: 5246
*Aug 29 20:02:13.255: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.0.20.101 peer_port: 5246
*Aug 29 20:02:13.255: %CAPWAP-5-SENDJOIN: sending Join Request to 10.0.20.101
*Aug 29 20:02:13.263: %DTLS-5-ALERT: Received WARNING : Close notify alert from 10.0.20.101
*Aug 29 20:02:13.263: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.0.20.101:5246
*Aug 29 20:02:39.263: AP has SHA2 MIC certificate - Using SHA2 MIC certificate for DTLS.
I tried to have the 2700 ap join a C9800 CLoud, running 17.9.3 and the access point joined the controller. So now the AP is running the correct ap3g2-k9w8-mx.153-3.JPN2, but It will not join the 9115 EWC.
WLCC884.A1AB.5770#wireless config vwlc-ssc key-size 2048 signature-algo sha256 password 0 Stabbestad1
Configuring vWLC-SSC...
WLCC884.A1AB.5770#show wireless management trustpoint
Trustpoint Name : CISCO_IDEVID_SUDI
Certificate Info : Available
Certificate Type : MIC
Certificate Hash : 32487782d79cb30b233c2e040663ae7f58dc0a9b
Private key Info : Available
FIPS suitability : Not Applicable
I have manually removed ntp and set the time to before 5 dec 2022.
Mark Elsen
 - The 2700 model is not supported on the EWC based controller(s) : https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html#c9800-embed-ctr-ap_support
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Mark Elsen
 M.
       Beauty and terror
      Just keep going
       No feeling is final
I must have seen wrong, and seen the 9800 cloud version over and over again. Thanks a bunch marce, this made my day easier!
