EWC-vlan setting concept
vTaroko
Frequent Visitor
Frequent Visitor
  • EWC based on C9115AXE with Cisco IOS XE Software, Version 17.03.03
  • x2 WLAN mapping to VLAN10 and VLAN20 with simple PSK security.
  • All STA with manual fixed IP address can connect to internet very well.
In the Policy Profile, mapping SSID-10 to VLAN10 and SSID-20 to VLAN20
In the Flex Profile, ONLY setting Native VLAN ID without going to add VLAN-Name and VLAN-ID
As I know, EWC only support FlexConnect-Local Switching not Central Switching.
The setting of VLAN-Name and VLAN-ID in Flex Profile is where we can create VLANs that will be pushed down to the AP.
I don't have anything set up in Flex Profile about VLAN-Name and VLAN-ID, but it still works.
So, what's the correct concept about this VLAN settings in Flex Profile ?
Thanks for your response.
NikolaiErovenko97239
Community Member
Maybe this will help you https://www.cisco.com/c/en/us/products/collateral/wireless/embedded-wireless-controller-catalyst-access-points/white-paper-c11-743398.html#Productoverview
 I make the same config, but point do not want to use a right VLANs. How have you configured VLANs (switch, ports, ewlc)?
