External Wireless Access Point
Mohammad-
Level 3
Level 3
Hi Guys,
i am planning to AIR-AP1562E-M external access point, but not sure about Antenna selection.
Could you please help me understand for antenna Selection for External Access Point and minimum count for Antenna ?
Cisco Champ
Sandeep Choudhary
Check Table 4 to learn about the antenna requirements:
https://www.cisco.com/c/en/us/products/collateral/wireless/aironet-1560-series/guide-c07-737428.html
Dont forget to rate helpful posts
Thanks Sandeep for your prompt response.
I will check and update you with my findings.
Does existing Cisco Prime to manage the CMX?.
Do they need additional licences on Cisco Prime in order to manage CMX?
Can someone help me please..
Does existing Cisco Prime can manage the CMX?.
or do they required additional licences on Cisco Prime in order to manage CMX?
