Failed license installation at index:0: New count is less than existing coun
Hello My Friends
Now,I have a problem,
We have a WLC5508 with 25 AP capacity,but we want to adder 5 APs capacity to the WLC5508.
When we try to add the license to WLC5508,show the error as below:
"Failed license installation at index:0: New count is less than existing coun"
So,what's problem with it?
This is the license file's info:
Product Name               : L-LIC-CT5508-UPG
Product Description        : Primary SKU for CT5508 upgrade licenses (Delivery via Email)
Product Qty                : 1    UDI                        :
PID: AIR-CT5508-K9  SN: FCW2203B2XZ
Order Number               : 105603053
Product Authorization Key  :  XLPL8F8M8UE
Options Included               QuantityOptions Included               Total Quantity  Available Quantity  Requested QuantityL-LIC-CT5508-5A                1               0                   1
Rps-Cheers | If it solves your problem, please mark as answer. Thanks !
5 Replies 5
Sandeep Choudhary
Are you sure its an adder license and not a base license!!! That can be the issue.
Have you also rebooted the WLC? If they provided you or if they sold you a base license, you will have to get that fixed first. An adder license is what's required.
Dont forget to rate helpful posts
HI  Sandeep
This picture is my license description,it's not a adder license?
L-LIC-CT5508-5A - Its the addrer license....
 Make sure the license  information like Serial Number  is correct.
 Download the file again, this can be a corrupt file. Add to the WLC using an reliable network to avoid any transfer isso.
 Lastly open an license tac if you think everything should be ok.
-If I helped you somehow, please, rate it as useful.-
I have resolved the issue,it's wrong licence with 5 AP,it should be 30 APs,after cisco license team give me the correct license,it run well.
