Failed to add device to WCS Reason: Unified AP with same MacAddress already exists in WCS. Please remove Unified AP first.
Ryan Ketchum
I am trying to add an AP (1231G)  with autonomous code (Version 12.3(8)JEC2)  to WCS (v7.0.172.0).  I recieved the following error:
I went to configure --> access points --> "placed check marks next to existing AP" --> selected Remove AP command --> Go
I verfied the AP was removed.
I am still getting the same error.
I did a search of WCS by MAC and IP and it did not find any results.
Is there another place that I need to look?
What am I missing?
Thank you for your help.
Ryan
maldehne
search for unassociated APs from WCS and remove the resulting list of APs.
Then try
9 Replies 9
Stephen Rodriguez
Sounds like there may be a stale entry in the DB. I'd open a TAC case and have them walk the DB and remove the entry if it exists
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Thank you.  This seems like a reasonable cause to my problem.  I will see what TAC has to say.
Ryan
Leo Laohoo
I haven't seen this error message since the 6.X WCS codes.
Can I ask if you can upgrade the WCS to 7.0.2XX.0 code?
Thank you for your reply and input.  I am currently using WCS version 7.0.172.0
Are you saying that Version 7.0.2xx.0 would resolve this issue?
Ryan
maldehne
Then try
As far as I can tell there is no way to search by an unassociated APs "as a category".  There was a choice in "Advanced Search" to choose to search by access point.
Do you mind providing me some instruction on how to search by unassociated APs.  I would be interested to see if this AP is maybe "hidden" from view and if a search by unassoicated APs would reveal it.
Ryan
I mean the WCS 7.0.230.0 has fixed a few bugs.  So I wouldn't be asking you to load the older firmware.
Advanced Search
Search Category --> Access Points
Search by ---> Unassigned APs
See if you have any result
I was blind as a bat!  Thank you for the that. (I actually found it in the "unassociated" list, but you led me in the right direction)
It also resolved my issue.  Even though I deleted the AP from the configure AP screen they still showed up when I searched "unassociated APs" in the advanced search.
I am now able to re-add it.
@ Steve - Maybe this was the DB orphan you were refereing too?
Thank you
Ryan
