Filter to show APs with clients.
Smason
How do I  create a filter by AP on my 4400 series WLC to show all the clients associated to those APs?  Thanks in advance.
braggb001
Samantha,
     This may be different depending on the version of code you are running, but this would be how you do it when running ver. 4.2.176.0
  1. Web into the Controller
  2. With the "Monitor" tab selected (home screen) click the "Clients" link on the left.
  3. Near the top click the "Change Filter" link
  4. Check the box next to "AP Name"
  5. Enter the name of the Access-Point you would like to filter by
That should be it.  Hope this helps.
braggb001
Samantha,
Thank you it worked.
Great post Bragg 5+ !
If you have WCS you can pull this reporting as well!
