firepower
u.drechsel
Hi all,
I'm using ASA5585-X with Firepower 6.2.0.1 and I want to blacklist old and unsecure operating systems like Windos XP and below. Does anybody know a way to do this?
Thank you in advance
Uwe
Operating Systems are found through the FireSIGHT process (now called AVC).  This is a passive process.
There is not an option to create objects based on OS types, thus no way to enforce on that object.
The FireSIGHT process is meant to be informative for the security engineer. It allows you to be be aware and to discover systems you might not have known were on your network.
If you want to block / black hole an OS, you need need ISE.  ISE can make differentiated access policy decisions based on the OS when doing posturing.
OK, than I have to wait untill we've bought our ISE.
Thank you for your quick answer.
greetings,
Uwe
