Firewall for wireless deployment
Jonn cos
Level 9
Level 9
Hi all,
I am currently working on a client RFP. They are inquiring about wireless controllers and AP alongwith Firewall and IPS/IDS solution for wireless. I want to know that does wireless lan controller (5760 in this case) supports firewall/IPS/IDS or is there any other box designed for this purpose ?
Scott Fella
To be honest... No. Cisco has a wIPS feature but that requires NCS or Prime infrastructure along with an MSE. There is no built in firewall. They must be looking at an Aruba solution to be honest.
-Scott
Shaoqin Li
Level 6
Level 6
basic wips provided by wlc itself while advanced wips comes with MSE
Abhishek Abhishek
As per your query i can suggest you the following solution-
No, wireless lan controller (5760 in this case) supports firewall/IPS/IDS .
Hope this will help you.
