Firewall rules and bridge mode enabled
jjabson
Level 4
Level 4
I have a question regarding firewall rules and when the AP is set to Bridge mode. My understanding when Bridge mode is enabled, clients obtain IPs from an upstream DHCP server. Can I still use firewall rules even if the AP isn't managing the IP pool being given to the clients?
Thanks in advance,
-Jerome
pjc
Level 4
Level 4
Yes, you can. Firewall rules are setup in the same way per SSiD. Just make sure that at the bottom of your layer 3 rules, you deny Local Lan access (if that's the intention)
simple818
Level 9
Level 9
If someone else doesn't know off the top of their head I could test this on my home network later. That is the only Meraki network I have setup in Bridge mode. Would be pretty easy to confirm. Just add a layer 7 firewall rule to block a specific website and then try to navigate to that website from the wireless network.
Adam R MS | CISSP, CISM, VCP, MCITP, CCNP, ITILv3, CMNO
If this was helpful click the Kudo button below
If my reply solved your issue, please mark it as a solution.
pjc
Level 4
Level 4
@pjc
@simple818
Thanks for your help!
