Firmware 12.03T and the 350 series Access Points
After the last firmware upgrade to 12.03T all the access points that I had forced to the left or right side (depending on the antenna AIR-ANT1728 placement) seem to work better if I set it back to diversity.
Any ideas on this when 12.02T did not give us this problem? I am about to change them all back to diversity.
k.poplitz
Level 3
Level 3
Did you check the bug tool kit for any known issues with 12.03T??
Thanks for the advice. I did not find anything related to this with 12.03T.
