Firmware Compatibility
golan.jovani
Community Member
I have a Cisco WLC 2500 series with firmware 7.4.121.0,and  AP model AIR-LAP1131AG-E-K9   connected to it .
i want to add one new AP and it's model is AIR-CAP3702I-E-K9 .
I would like to know which firmware version i need to upgrade my WLC so all AP's will be working.
adawa
Level 7
Level 7
Hello, golvan.jovani.
You need to have at least 7.6.X to support the new Aironet 3702i APs. Check this software compatibility matrix for reference:
http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
This should also support 1130 AP models. Are you using other other Cisco AP models?
Let me know if you have additional concerns or e-mail ([email protected]) me directly. Kind regards.
Rasika Nayanajith
7.6.130.0 is the one you should go for from stability perspective.
Also make sure your FUS upgraded to 1.9.0.0 as well. This is required 30-40min downtime to your wireless & do it via CLI.
http://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/fus_rn_OL-31390-01.html
Rasika
*** Pls rate all useful responses ***
Moin Ilyas
Level 8
Level 8
Cisco WLC Release
Access Point IOS Release
Supported Access Points
8.0.100.0
15.3(3)JAB /12.4(25e)JAP
Lightweight APs: 1040, 1130, 1140, 1240, 1250, 1260, 1600, 1700, 2600, 2700, 3500e, 3500i, 3500p, 3600e, 3600i, 3600p, 3702e, 3702i, 3702p, 600 OEAP, 700, 700W, AP801, and AP802
Outdoor Mesh APs: 1522, 1524PS, 1524SB, 1532E, 1532I, 1552E, 1552H, 1552I, 1552C, 1552EU, 1552CU, and 1552S
7.6.130.0
15.2(4)JB6/12.4.25e-JAO6
Lightweight APs: 1040, 1130, 1140, 1240, 1250, 1260, 1600, 2600, 2700, 3500e, 3500i, 3500p, 3600e, 3600i, 3600p, 3702e, 3702i, 3702p, 600 OEAP, 700, 700W, AP801, and AP802
7.6.120.0
15.2(4)JB5/12.4(25e)JAO5
7.6.110.0
15.2(4)JB4/12.4(25e)JAO4
Lightweight APs: 1040, 1130, 1140, 1240, 1250, 1260, 1600, 2600, 3500e, 3500i, 3500p, 3600e, 3600i, 3600p, 3702e, 3702i, 3702p, 600 OEAP, 700, AP801, and AP802
7.6.100.0
15.2(4)JB3/12.4(25e)JAO3
Cisco WLC Release 7.6.X or higher would work in your case.
Hope that helps.
bsiapco
Level 4
Level 4
golan.jovani May I know what happenned with this requirement? If you need further assistance please email me at ([email protected])
Thanks!
Barry
