Fixed wireless solution
sspoiala
Community Member
Does Cisco have a solution for transporting TV channels, data and voice over a 3.5 Ghz network ? We currently have deployed a 3.5 GHz network using Alvarion equipments.
Many thanks
kmarrero
Level 8
Level 8
Cisco does not have any 3.5 Ghz equipment. You can take a look at the product catalog and find routers and switches that will accommodate the traffic you will be sending across the network. http://www.cisco.com/univercd/cc/td/doc/pcat/
