Flex connect with Captive portal
Sunish Nair
Can i know that is it possible to configure Captive Portal with flex connect scenario. If yes if you can provide me some guidance it will be great.
Txs STN
Hi, two persons have confirmed me that they have tried it and it magically work. Currently I have the same question and I'm asking to a pre-sales from cisco if the support is official or not.
On of my colleague run it in a production site.
Perhaps I'll have soon more info about this.
Best Regards
Miguel
Yes it works and it is supported as stated in the FlexConnect Feature Matrix (internal Webauth).
When a client associates to the WLAN, the pre-auth ALC will allow DHCP and DNS and traffic. The next step is that when a client tries to reach a website it will be redirected by the WLC to the virtual IP address of the WLC. This traffic is being tunneled by the AP into a CAPWAP tunnel to the management interface of the WLC, in this way there is no need for end-to-end IP connectivity between the client and the WLC.
