Flex Controller Design
m.stefani
Community Member
just want  to know if it is poosible to have a 7500 Flex Controller  Cluster in diffrent Locations, like Germany an Australia?
This should be deployed as a redudant system, in case of a failure in one location the remaing Cluster can take over.
Also the main maintenance/management should be done in the Headquarter (Germany).
Is it possible to configure Guest Access via Web Interface.
Last question: how many AP`s can be managed, example: with one Controller 500 AP can I then manage 1000 with two controller?
Thanks and Regards
Michael S.
Stephen Rodriguez
yea that is possible, so long as your configs are the same across both WLC.
Currently one 7500 can manage up to 2000 AP.
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Hi Steve,
thanks a lot for your answer.
As these are questions from our customer I am just the one who redirect it to you.
The customer wants to make sure that his requirements are realizable.
So if you say yes that means, yes to which question...?:
just want to know if it is possible to have a 7500 Flex Controller Cluster in different Locations, like Germany and Australia?
This should be deployed as a redundant system, in case of a failure in one location the remaing Cluster can take over.
That actually means is the amount of AP depending of the number of Controller I am using?
Please feel free to add comments in the questions above.
Michael
Von: steprodr
Gesendet: Montag, 6. Februar 2012 15:05
An: Stefani, Michael
Betreff: - Re: Flex Controller Design
Home <>
created by Stephen Rodriguez <> in Other Wireless - Mobility Subjects - View the full discussion <>
The answer was yes to all.  You can 'cluster'/mobility group config the WLC, for failover.  Yes, you can do a webauth for guests.
http://www.cisco.com/en/US/products/ps11635/products_tech_note09186a0080b7f141.shtml
Steve
HTH,
Steve
Hi Steve,
thanks a lot..
Michael
Von: steprodr
Gesendet: Montag, 6. Februar 2012 15:30
Home <>
