Flexconnect and avc
From what I understand now the situation is that AVC doesn't work when using flexconnect in local switching mode at least as of 8.0.115.0. My question is will it ever be supported in flexconnect mode. I got cases where I have APs in flexconnect mode and would like to see statistics as well as block certain types of traffic which is available in the AVC profiles.
Br //Peter
Freerk Terpstra
Level 7
Level 7
AVC with FlexConnect will be supported in 8.1 code on for all WLC's (including the vWLC) expect the 2504. I don't know if you have access to Cisco's Partner Education Connection, but if you do I recommend the 8.1 Wireless Controller update video for more information :-)
Freerk Terpstra
Level 7
Level 7
I do have that access, however it was in maintenance right now. Thank you for the information.
Br //Peter
I don't think AVC  will be supported ever for Flexconnect APs in the 2504
Release Notes for Cisco Wireless Controllers and Lightweight Access Points for Cisco Wireless Release 8.3.102.0
http://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn83.html
Features Not Supported on Cisco 2504 WLC
  • Autoinstall
  • Cisco WLC integration with Lync SDN API
  • Application Visibility and Control (AVC) for FlexConnect local switched access points
  • Application Visibility and Control (AVC) for FlexConnect centrally switched access points
