08-19-2013 05:36 AM - edited 07-04-2021 12:40 AM
I have realized that when the AP reboot, it doesn´t keep the custom power level that I assigned, this issue doesn´t happend if the AP is in local mode, when the AP is in local mode it keeps the custom power level assignment after reboot, I have a WLC 5508 with 7.4.100.0 software version and APs AIR-CAP3602I-N-K9, I will be greatful if someone knows how to fix this problem
thanks a lot.
Solved! Go to Solution.
08-19-2013 02:40 PM
Alejandro,
You are hitting a known caveat:
| CSCug79785 |
| 3600 AP does not retain static power configuration after 2nd reboot |
| Symptom: Statically assigned power level on 3600 is not retained after 2 reboots. Conditions: Manual power configuration on AP Workaround: Manually set the power level again. |
This is resolved in the latest releease 7.4.110.0.
Cheers,
Erwin
______________________________________
How helpful was I? Don't forget to rate me when you have the chance!
08-19-2013 02:40 PM
Alejandro,
| CSCug79785 |
Cheers,
Erwin
