01-26-2013 04:30 AM - edited 07-03-2021 11:25 PM
Scenario : We are deployed the WLC in Corparate Office and Access Points are placed in Branch Office with FlexConnect Local Switching mode.
In this case, I am not able to Ping the Wireless clients eachother . Peer to Peer Block Option also Disabled.
Some time Wireless clients Ping eachother & some times not. Both Wireless clients are associated with Same AP & Same WLAN SSID.
Please help me urgent ..
Devices :
1)WLC 2500 series , Software 7.2
2)Cisco 1400 series APs
3)CISCO ACS server for AAA authentication
Shanmugam Nachimuthu
Solved! Go to Solution.
01-29-2013 09:36 PM
Hi Shanmugam,
Please apply following steps to configure P2P setting for WLAN:
Step 1 Choose WLANs to open the WLANs page.
Step 2 Click the ID number of the WLAN for which you want to configure peer-to-peer blocking.
Step 3 Choose the Advanced tab to open the WLANs > Edit (Advanced) page.
Step 4 Choose one of the following options from the P2P Blocking drop-down list:
• Disabled — Disables peer-to-peer blocking and bridges traffic locally within the controller whenever possible. This is the default value.
NOTE: Traffic is never bridged across VLANs in the controller.
• Drop—Causes the controller to discard the packets.
• Forward - Upstream — causes the packets to be forwarded on the upstream VLAN. The device above the controller decides what action to take regarding the packets.
NOTE: To enable peer-to-peer blocking on a WLAN configured for FlexConnect local switching, select Drop from the P2P Blocking drop-down list and select the FlexConnect Local Switching check box.
Step 5 Click Apply to commit your changes.
Step 6 Click Save Configuration to save your changes.
Prashant Gondaliya
01-27-2013 08:16 AM
Please help me urgent..
01-29-2013 09:36 PM
Hi Shanmugam,
Prashant Gondaliya
01-29-2013 10:17 PM
Hi Prashant Ji,
Thanks for your reply.
The P2P setting for WLAN is already disabled only..
WLAN L2 Security settings option WPA gtk-randomize option was enabled.This option kills the broadcast and multicasts in that WLAN. So we disabled that option , its working fine now.
Below options also changed.
N.Shanmugam
01-29-2013 10:42 PM
Thanks for sharing valuable details and giving rating for the post.
Prashant Gondaliya
