07-16-2015 09:22 PM - edited 07-05-2021 03:35 AM
Hi all ,
I have all of my APs configured under flexconnect at the remote site .
I have one controller at the main office .
There are two redundant MPLS links going from the main office to the remote site .
Now the issue is , whenever my MPLS does a failover to the redundant link , all of my flexconnect APs disappear from the controller .
I understand that this is due to the heartbeat timer getting expired , and the AP moving into Standalone mode .
But the flexconnect APs take an awfully long time , to shift back to connected mode , after the MPLS failover completes ( which is usually half a minute max ).
Infact it takes such a long time that , i have to manually shut/reset the switch-ports(POE) on which all the APs on the remote site are connected !!
Is there some tweaking that i am missing here ? or should i be upgrading my firmware ? By the way my controller is currently on S/W ver : 7.4.121.0.
Solved! Go to Solution.
07-18-2015 02:09 AM
If you have a test controller you can test this with different code of WLC software. Otherwise reach Cisco TAC and see any known issues with this code on this.
Rasika
07-18-2015 02:09 AM
Rasika
07-19-2015 11:27 PM
Hi ,
Thanks for the reply . Even as i am typing now,I have got two APs disappeared from controller , but pingable and can telnet into it !!
This is to LOG output.
*Jul 20 06:03:34.639: %CAPWAP-3-ERRORLOG: Retransmission count for packet exceeded max(CAPWAP_WTP_EVENT_REQUEST
., 3)
*Jul 20 06:03:34.643: %LWAPP-3-CLIENTERRORLOG: Switching to Standalone mode
Yes i think i will go for the code upgrade as you suggested and will recheck !
05-04-2020 08:52 AM
Hi Rahul,
Did you try the code upgrade. Did it resolve the issue ?
Aadhil
