12-05-2023 11:05 AM
We're using Cisco ISE version 3.2 patch 4. Cisco 5520 WLC version 8.10.183.0.
I implemented FlexConnect. I'm seeing clients show up Wired and Wireless clients in Cisco ISE. The Wireless authentications show the WLC as the Network Device, NAS port type as 802.11, and use dot1x authentication. The wired authentications show the Switch the AP is connected to as the Network Device, NAS port type as ethernet, and use MAB authentication.
Is there a way to prevent the wireless clients from authenticating via the switch and wired MAB?
Solved! Go to Solution.
12-05-2023 09:54 PM
No need anything except remove 802.1x from port connect to AP.
Why you need two l2 secuirty in your network.
MHM
12-05-2023 09:27 PM
if you asking to prevent wireless devices from connecting to wired jacks, then yes use port security, don't think you can do any other way or if the devices are managed through some central control like mdm then something at device level can done.
12-05-2023 09:54 PM
MHM
12-05-2023 10:01 PM
how would that stop a laptop on wireless to hook into a wall jack ?
12-05-2023 10:06 PM
Only the port connect to AP disable 802.1x other sw port he can use it.
12-05-2023 10:11 PM
actually i should have asked you this before, it is the same mac address you are seeing as wired and wireless client on ISE ?
01-16-2024 05:41 AM
Sorry for the late reply. Yes I am seeing the same MAC for the wired and wireless authentications. I removed the 802.1x config on the port and the clients are showing correctly now. They're authing via the WLC
