Anchor/Mobility issue between 5520 9800L Foreign and Anchor WLCs
craiglebutt
Level 4
Level 4
I've have mobility anchors between our company and other companyss who we have staff in each others buildings.
I have 5520 & 8510s which are both anchor and foreign for certain SSIDs .  External companys have 9800, so the 5520s and 8510s have teh correct lastest ICRM.
Before I go live with these new 9800 trying o test teh anchor in a lab, the anchors are up, ssid config the same.
9800 (Foreing) -> 5520 (Anchor) works fine
5520 (Foreing) -> 9800 (Anchor) doesn't work.
 %CLIENT_ORCH_LOG-4-ANCHOR_INVALID_MBSSID: Chassis 1 R0/0: wncd: Export anchor required but config is incorrect (e.g.: wlan should be up, wlan profile name and policy profile name should match) for: Wlan-Profile: 8500_New_Corp_WLAN, Policy Profile: 8500_New_Corp_WLAN, client MAC:
Cheers
balaji.bandi
You can find the information about the Logs :
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/16_xe/smg/xe-16-10/b-sem-16-10-1/b-sem-16-10-x_chapter_00.html
what version airos - ( make sure you have IRCM compatibility with AireOS - i am sure you have upgrade WLC 5K to that version - but check again).
and verify the config as below :
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/213912-configure-mobility-anchor-on-catalyst-98.html
BB
cheers, I've already looked through them, someting just right cheers
