Flexconnect Roaming
IT Services
Level 4
Level 4
Good Afternoon,
I had a quick question about romaing with Flex Connect AP's. Looking at this article:
http://www.cisco.com/en/US/products/ps10315/products_tech_note09186a0080b3690b.shtml
As far as mobility/roaming is concerned. What do they mean by Fast Roam and Full Auth. Does Full Auth indicate that the clients do not essentially roam and that they will reauthenticate to the new AP?
Also looking at the Client Roaming setting in the WLC 5508 (running 7.2.111.3) does it only pertain to CCX enabled devices, or are these settings to configure roaming for non CCX devices as well?
I just noticed we have high density on one our of AP's in an office and it does not seem like clients are moving over to other AP's with stronger signal, etc.
Stephen Rodriguez
Fast Roam would be the 4-way handshake with the PMKID.
Full Auth would be that credentials get passed back to the AAA server.
Most of the 'Client Roaming' is CCX, the device has to understand what is being passed between the WLC and itself.  And I can't think of a time that I"ve actually had to change those parameters.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
* Does this mean that the clients would see little if any interruptions when roaming to another AP?
* Does this entail that the users would see interruptions in communication?
*  Without modifying these at what threshold does the client roam to another AP within the same mobility group (controller).
These are currently in FlexConnect mode for us too.
HTH,
Steve
Realistically it's possible that the client won't see an issue either way.  I've been testing with WPA2/AES on a device that fully auths every time, and haven't had an issue.  But the potential that you can have an issue going to AAA increases.  But also depends on what type of devices you are using.
HTH,
Steve
HTH,
Steve
What variables or thresholds does Roaming take into consideration?
Is any of these configurable? If so is it conifgured on the Client Roaming tab of the RF policy?
