FlexConnect
Not applicable
Can I do a flexconnect for a small office has local Internet connection?  All company applications are centralized at a remote datacenter but not Internet access.
Sandeep Choudhary
flexconnect need a wan connection between 2 sites. if its not there then it wold not be possible.
H-Reap Design and Deployment Guide
http://www.cisco.com/c/en/us/support/docs/wireless/5500-series-wireless-controllers/71250-h-reap-design-deploy.html
H-REAP Modes of Operation Configuration Example
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/81680-hreap-modes.html
hope it helps.
dont forget to rate helpful posts
Sandeep,
Thanks for the information.  Branch office has two wan circuits.  My concern is if wifi internet traffic will go out local internet circuit directly.  WLC is running on 7.4.121.
You can achieve this with Flexconnect Local Switching.
Abhishek Abhishek
Please refer to the H-Reap design and deployment guide.
