Force ap to join secondary controller
acomiskey
Level 11
Level 11
I currently have 2 2106 wlc's.
Each is licensed for 6 access points. Controller 1 is full. Controller 2 has 5/6 aps.
When I add the 12th access point it repeatedly attempts to connect to controller 1. It never tries to connect to controller 2.
In the ap config I have specified the names of the primary and secondary controllers.
Primary - Controller_2
Secondary - Controller_1
Shouldn't this force the ap to attempt to connect to Controller_2?
Rob Huffman
Hi Adam,
Can you try setting WLC # 2 into "Master Controller" mode?
Hope this helps!
Rob
Thanks Rob.
Turns out I had to set each controller in the same Mobility Group and add each others MAC/IP addresses into the Mobility Group Members. It now appears to use the primary controller first.
Hi Adam,
Nice work! All the best to you in 2008 🙂
Take care,
Rob
