Forcing A WiFi Device to Join to An Access Point
Shao-Yu Chen
This is just an idea, and hope it can be done. I would like to test out WCL or WISM current configuration settings on a remote site. I know I can have a lightweight AP configured and joined to the remote site's wireless controller. Now my question is how would I force my wireless device to join to the AP in front of me?! If this is doable then it will help me to troubleshoot 13 remote sites right from my office. Is there a place where I can add my WiFi device's MAC address to a specific AP? Thank you for the help.
11 Replies 11
Stephen Rodriguez
the client makes the decision on which AP to join based on RSSI + SNR + what ever magic the vendor put in place
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Leo Laohoo
The decision to join which AP is the sole responsibility of the wireless NIC card of the client.
You can help "influence" this by improving some of the settings on the WLC.  One of them is disable low-speed data rates from 11 Mbps and below.  Make 12 Mbps as "Mandatory" and the rest are "Supported"
You can also upgrade your wireless NIC card.  Intel has a bad run of 802.11n cards lately.  Until recently, all their drivers were useless.  I believed they released a "jumbo" pack a few months ago which helps wireless cards operate in 802.1n environment.
Shao-Yu Chen
I have iPad users who are complaining their connection at the remote sites. District staff take their iPad and not be able to join the SSID we have created or very slow to get connected. At those sites, we have 5508 or 4402 WCL in place. The access points are 1231G in lightweight mode. For me to run a test for their connection quality, I might have to visit each site, and that's why I came up with this question. Since the device makes the decision on which AP to join, then I can isolate myself with no other APs in the area, and run the test. I could be making a testing lab with a 1231G AP joined with remote site's WCL in an isolated room and be able test out all possible wireless devices that school district carries. Does that sound right? Thank you for your inputs.
Post your show WLAN
-Scott
(Cisco Controller) >show wlan 5
WLAN Identifier.................................. 5
Profile Name..................................... sdocstudent
Network Name (SSID).............................. sdocstudent
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Disabled
AAA Policy Override.............................. Disabled
Network Admission Control
  Client Profiling Status ....................... Disabled
  Radius-NAC State............................... Disabled
  SNMP-NAC State................................. Disabled
  Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Maximum number of Clients per AP Radio........... 200
Number of Active Clients......................... 18
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. 1800 seconds
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ sdocstudent
--More-- or (q)uit
Multicast Interface.............................. Not Configured
WLAN IPv4 ACL.................................... unconfigured
WLAN IPv6 ACL.................................... unconfigured
DHCP Server...................................... Default
DHCP Address Assignment Required................. Disabled
Static IP client tunneling....................... Disabled
Quality of Service............................... Silver
Scan Defer Priority.............................. 5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
--More-- or (q)uit
   Authentication................................ 10.1.1.25x aaaa
   Authentication................................ 10.1.1.25y aaaa
   Accounting.................................... 10.1.1.25x bbbb
   Accounting.................................... 10.1.1.25y bbbb
      Interim Update............................. Disabled
   Dynamic Interface............................. Disabled
Local EAP Authentication......................... Disabled
Security
   802.11 Authentication:........................ Open System
   FT Support.................................... Disabled
   Static WEP Keys............................... Disabled
   802.1X........................................ Disabled
   Wi-Fi Protected Access (WPA/WPA2)............. Enabled
      WPA (SSN IE)............................... Disabled
      WPA2 (RSN IE).............................. Enabled
         TKIP Cipher............................. Disabled
         AES Cipher.............................. Enabled
                                                               Auth Key Management
         802.1x.................................. Enabled
         PSK..................................... Disabled
         CCKM.................................... Disabled
         FT-1X(802.11r).......................... Disabled
--More-- or (q)uit
         FT-PSK(802.11r)......................... Disabled
      FT Reassociation Timeout................... 20
      FT Over-The-DS mode........................ Enabled
      GTK Randomization.......................... Disabled
      SKC Cache Support.......................... Disabled
      CCKM TSF Tolerance......................... 1000
   Wi-Fi Direct policy configured................ Disabled
   EAP-Passthrough............................... Disabled
   CKIP ......................................... Disabled
   Web Based Authentication...................... Disabled
   Web-Passthrough............................... Disabled
   Conditional Web Redirect...................... Disabled
   Splash-Page Web Redirect...................... Disabled
   Auto Anchor................................... Disabled
   FlexConnect Local Switching................... Disabled
   FlexConnect Local Authentication.............. Disabled
   FlexConnect Learn IP Address.................. Enabled
   Client MFP.................................... Optional
   Tkip MIC Countermeasure Hold-down Timer....... 60
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
--More-- or (q)uit
KTS based CAC Policy............................. Disabled
Band Select...................................... Disabled
Load Balancing................................... Disabled
Multicast Buffer................................. Disabled
Mobility Anchor List
WLAN ID     IP Address            Status
802.11u........................................ Disabled
  Access Network type............................ Not configured
  Network Authentication type.................... Not configured
  Internet service............................... Disabled
  HESSID......................................... 00:00:00:00:00:00
Hotspot 2.0.................................... Disabled
  WAN Metrics configuration
    Link status.................................. 0
    Link symmetry................................ 0
    Downlink speed............................... 0
    Uplink speed................................. 0
--More-- or (q)uit
Mobility Services Advertisement Protocol....... Disabled
Firstly, you've got 1231 so which probably means you only have 802.11b enabled.  If there's only one radio, sniff the air for any co-channel interferrence.  Do you have dynamic DCA and TPC enabled?
Next, can you try to create a PSK or even OPEN and see if there are any login improvements?  Have you checked MS AD and see through the logs the event of what happened when users attempt slow login?
Just adding....to all other answers....
There is not a way to force the wifi device to use a specific AP from the  controller side of things.  As per the specs the client decides when and  where to associate.  You could try disabling some of the lower data  rates or lowering the AP's tx power to reduce the coverage cell of each  AP.  By doing this the client might not see the other AP as favorable.
Reagrds
Not too sure if I want to do that in our environment. Do not want to interrupt other users wireless connectivity during my test with a specific access point.
What would you do if you have 10 different mobile devices and want to test them out to see how well they will react to a remote WCL? Take those 10 devices from site to site? We have 23 remote sites with WCL and WISM. Or test them in an office with an AP joined to a remote WCL? But I do not want to alter other APs in the area to make office people angry.
I have >98 schools to manage my wire and wireless.  I've never seen a behaviour like yours.  Then again, I don't have AP1230 in my network anymore.
Not really sure when the 1231G will be phase out totally. Some schools have controller either WCL or WISM with 1231G joined. We have been converting lots of 1231G to light weight, so we can easily change from WEP to WPA2, and also start implementing BYOD to schools that are equiped with light weight access points. BYOD is new to us, and just started this year. My team lead just announced another wireless upgrade to our core sites, and finally we will be getting ICE and Cisco Prime. With that I hope the new installation will improve users using all types of mobile devices. In the mean time we are just patching holes on a flat tire.
Ok, you're not going to get any benefits with BYOD if the 1230 will be there.
1230 are only 802.11b/g.  You can stick 802.11a radio module but at the end of the day, the 1230's FastEthernet port will be one of the bottlenecks.
In regards to WPA2, the 1230 needs to have a radio upgrade AIR-MP21G-X-K9.
Too many hassles to get an old product to support BYOD.  Plus it's already end-of-support.  If your AP dies, you have to pay a fortune in Service Contract.
You're better off getting the APs upgraded.  Talk to your Cisco SE/AM and ask them about Cisco Technology Migration Platform.  This program means that you can get a discount for every old equipment (including non-Cisco) traded-in, like-for-like.   Say you traded-in 20 APs, then you get a $$ off 20 new Cisco APs.  You can't trade in 20 APs and hope to get $$ off 21 APs.
