access point in ap: mode
suthomas1
Level 6
Level 6
One of our 3502 is not loading with flash image, after someone erased flash.
the ap boots up & shows ap: prompt.
issuing a boot statement on this prompt gives message;
Loading "flash:/ap3g1-k9w8-mx.152-2.JB/ap3g1-k9w8-mx.152-2.JB"...flash:/ap3g1-k9
w8-mx.152-2.JB/ap3g1-k9w8-mx.152-2.JB: no such file or directory
Error loading "flash:/ap3g1-k9w8-mx.152-2.JB/ap3g1-k9w8-mx.152-2.JB"
Please help on how to restore this ap back with proper image & have it booted. Loading with autonomous image is also fine with us.
5 Replies 5
Scott Fella
Please refer to this link as it will explain how to upload a new image. You will need a support contract to download the image.
https://supportforums.cisco.com/thread/2043235
-Scott
Thanks Scott. I tried this using following:
ap: set IP_ADDR 192.168.100.2
ap: set NETMASK 255.255.255.0
ap: set DEFAULT_ROUTER 192.168.100.254
ap: tftp_init
tar -xtract tftp://192.168.100.1/images/ap3g1-k9w7-tar.152-4.JA1.tar flash:
tftp://192.168.100.1/images/ap3g1-k9w7-tar.152-4.JA1.tar: permission denied
It gives error of permission denied. there is no firewall turned on between this.
Appreciate all help.
permission denied
What machine is the TFTP?  If this is a Linux machine, make sure you allow READ permission on the file and folder.
Scott Fella
Verify the tftp root folder. Might be pointing to a different folder.
-Scott
Abha Jha
