Frequent 802.11b Interface Resets
naoui1
Frequent Visitor
Frequent Visitor
recently  one of our AIR-CAP1602I-E-K9 access points has started intermittently resetting its 802.11b interface.
The log messages on the WLC always look either like this:
AP's Interface:0(802.11b) Operation State Up: Base Radio MAC:34:db:fd:xx:xx:xx Cause=Indicates that while the radio state should be updated on controller, no reset should be reported. Status:NA
AP's Interface:0(802.11b) Operation State Down: Base Radio MAC:34:db:fd:xx:xx:xx Cause=Indicates that while the radio state should be updated on controller, no reset should be reported. Status:NA
We're using a AIR-CT2504-K9 WLC running  8.5.135.0, the Ap in question is AIR-CAP1602I-E-K9
Thank you,
0 Replies 0
