Generate CSR for Cisco WLC 2504
Gregorio310
Hello Team, i'm trying to genrate a CSR for an external CA and install on my WLC, but the comands that i tryed was not successfully completed.
anyone has any how to for it? I tryed this to but not sucessfull.
MY WLC is model 2504 and i want to get an external certificate for it.
Generate CSR for Third-Party Certificates and Download Unchained Certificates to the WLC - Cisco
How to Generate a CSR on a Cisco WLC - QuoVadis Customer Support
This thread may help.  Also, I've used 0.9.8 in the past with success.
https://supportforums.cisco.com/t5/getting-started-with-wireless/wlc2504-godaddy-com-certificate/td-p/2013519
Version 8.3 allows for support to do a CSR right from the GUI.  Not sure if that's available on the 2504 though.  I can check later this evening.
Philip D'Ath
It is very touchy about the version of openssl being used. Use the version specified in that document.
My controller is version
8.2.151.0 should i use openssl?
Yes, as that is what the instructions you posted said to do.
