Generating CSR for WLC 5508
nomadicwifi
Does Cisco WLC 5508 runnig code 6.0.196.0 allows you to generate CSR? Or do you have to use OPENSSL like in previous versions?
16 Replies 16
Hey guys,
After troubleshooting this with a TAC, we found out that Chained Certificates is not supported on the WLC till today. Not even on the latest version 7.0. I think I managed to upload the chained certificate successfully once but it still wouldn't work. It is a bug and still hasn't been resolved for Chained Certificates.
up to Level 2 Chained certificates are supported on WLCs running 5..1.151.0 or later code
Certificate Levels
  • Level 0—Use of only a server certificate on WLC.
  • Level 1—Use of server certificate on WLC and a CA root           certificate.
  • Level 2—Use of server certificate on WLC, one single CA intermediate           certificate, and a CA root certificate.
  • Level 3—Use of server certificate on WLC, two CA intermediate           certificates, and a CA root certificate. Level 3 or higher is not supported on           WLCs.
Changes have been made in openssl version 1.0.x which is not backwards compatible with previous versions of openssl.
So if you are using openssl version 1.0.x to create the final-cert.pem, this will not be supported with the WLC.
If you use openssl version 0.9.8, then you will be able to build the final-cert.pem and be able to load it on the WLC.
The following product enhancement request (PER) has been created for the WLC.
http://cdetsweb-prd.cisco.com/apps/goto?identifier=CSCti65315CSCti65315 - Need Support for certificates generated using OpenSSL v 1.0
