- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
01-17-2017 04:56 PM - edited 07-05-2021 06:23 AM
I have the following setup:
Cisco 1941-K9 2-Port Router w/Security IP Base License, and gigabit h-wic copper and gbic port
Cisco SG300-20
Cisco SG200-18
Cisco SG200-26
I am trying to add a Cisco Air CAP 1602i-A-K9 to the setup, but apparently I need a controller or I need to convert the 1602 to Autonomous. How do I go about converting this unit (I am assuming I need to)? I purchased the 1602 on eBay BNIB (factory sealed), have a Cisco Account, but I don't have a preferred seller to purchase a Contract from to get the update. How do I get the update, and do I need to pay for this every year? This is a setup for my home.
tia,
Ron
Solved! Go to Solution.
- Labels:
Aironet Access Points
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-29-2017 10:43 AM
As suspected, AP came with a lightweight image which require a WLC to make this AP working.
As long as you got a autonomous image ( eg- ap1g2-k9w7-tar.153-3.JD.tar), you can follow below post instructions to convert this to autonomous
https://mrncciew.com/2012/10/20/lightweight-to-autonomous-conversion/
Rasika
*** Pls rate all useful responses ***
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-17-2017 06:09 PM
Hi Ron,
Refer below posts on conversion process
https://mrncciew.com/2013/12/13/ap-conversion-using-mode-button/
ap2g1-k9w7-tar.xxx is the file you require. Check & see from the seller you able to get it
Rasika
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-17-2017 06:30 PM
Thanks, I have sent a message to the seller...hopefully he can get the file for me, if not i don't know what i am going to do.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-18-2017 12:54 AM
hi,
console to the AP and post here the boot up process. will let you know if you need to convert or not.
since this is a home setup, you just run the AP as autonomous/standalone.
see helpful link to setup an autonomous AP:
http://ccnawirelesswannabe.blogspot.com/2016/08/configuring-cisco-autonomous-standalone.html
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-19-2017 09:16 AM
Thanks, when I receive the unit I will post up the boot up process. Do I need to take pics of every screen or am I looking for a specific part?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-19-2017 12:02 PM
connect to it via CLI and provide
Rasika
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-29-2017 10:23 AM
Here is the boot text with version.
Cisco IOS Software, C1600 Software (AP1G2-RCVK9W8-M), Version 15.3(3)JA3, RELEAS E SOFTWARE (fc1) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2015 by Cisco Systems, Inc. Compiled Thu 19-Feb-15 09:33 by prod_rel_team ROM: Bootstrap program is C1600 boot loader BOOTLDR: C1600 Boot Loader (AP1G2-BOOT-M) LoaderVersion 15.2(2)JAX, RELEASE SOFT WARE (fc1) APe865.4921.06f0 uptime is 12 minutes System returned to ROM by power-on System image file is "flash:/ap1g2-rcvk9w8-mx/ap1g2-rcvk9w8-xx" Last reload reason: This product contains cryptographic features and is subject to United States and local country laws governing import, export, transfer and use. Delivery of Cisco cryptographic products does not imply third-party authority to import, export, distribute or use encryption. Importers, exporters, distributors and users are responsible for compliance with U.S. and local country laws. By using this product you agree to comply with applicable laws and regulations. If you are unable to comply with U.S. and local laws, return this product immediately. A summary of U.S. laws governing Cisco cryptographic products may be found at: http://www.cisco.com/wwl/export/crypto/tool/stqrg.html If you require further assistance please contact us by sending email to export@cisco.com. cisco AIR-CAP1602I-A-K9 (PowerPC) processor (revision B0) with 187382K/74672K by tes of memory. Processor board ID FCW1929N2RT PowerPC CPU at 533Mhz, revision number 0x2151 Last reset from power-on LWAPP image version 8.0.115.0 1 Gigabit Ethernet interface 32K bytes of flash-simulated non-volatile configuration memory. Base ethernet MAC Address: E8:65:49:21:06:F0 Part Number : 73-14671-04 PCA Assembly Number : 000-00000-00 PCA Revision Number : PCB Serial Number : FOC192898H9 Top Assembly Part Number : 800-102028-03 Top Assembly Serial Number : FCW1929N2RT Top Revision Number : A0 Product/Model Number : AIR-CAP1602I-A-K9
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-29-2017 10:24 AM
Here is the boot text..anything else needed?
Boot from flash IOS Bootloader - Starting system. FLASH CHIP: Spansion S25FL256 Xmodem file system is available. flashfs[0]: 11 files, 2 directories flashfs[0]: 0 orphaned files, 0 orphaned directories flashfs[0]: Total bytes: 31936000 flashfs[0]: Bytes used: 5918208 flashfs[0]: Bytes available: 26017792 flashfs[0]: flashfs fsck took 9 seconds. Reading cookie from SEEPROM Base Ethernet MAC address: e8:65:49:21:06:f0 ************* loopback_mode = 0 Loading "flash:/ap1g2-rcvk9w8-mx/ap1g2-rcvk9w8-mx"...############## File "flash:/ap1g2-rcvk9w8-mx/ap1g2-rcvk9w8-mx" uncompressed and installed, entry point: 0x2004000 executing... Secondary Bootloader - Starting system. FLASH CHIP: Spansion S25FL256 Xmodem file system is available. flashfs[0]: 11 files, 2 directories flashfs[0]: 0 orphaned files, 0 orphaned directories flashfs[0]: Total bytes: 31936000 flashfs[0]: Bytes used: 5918208 flashfs[0]: Bytes available: 26017792 flashfs[0]: flashfs fsck took 9 seconds. Reading cookie from SEEPROM Base Ethernet MAC address: e8:65:49:21:06:f0 Secondary bootloader Ethernet not enabled, skip ether_init Boot CMD: 'boot flash:/ap1g2-rcvk9w8-mx/ap1g2-rcvk9w8-xx;flash:/ap1g2-rcvk9w8-mx/ap1g2-rcvk9w8-xx' Loading "flash:/ap1g2-rcvk9w8-mx/ap1g2-rcvk9w8-xx"...####################### File "flash:/ap1g2-rcvk9w8-mx/ap1g2-rcvk9w8-xx" uncompressed and installed, entry point: 0x100000 executing... Restricted Rights Legend Use, duplication, or disclosure by the Government is subject to restrictions as set forth in subparagraph (c) of the Commercial Computer Software - Restricted Rights clause at FAR sec. 52.227-19 and subparagraph (c) (1) (ii) of the Rights in Technical Data and Computer Software clause at DFARS sec. 252.227-7013. cisco Systems, Inc. 170 West Tasman Drive San Jose, California 95134-1706 Cisco IOS Software, C1600 Software (AP1G2-RCVK9W8-M), Version 15.3(3)JA3, RELEASE SOFTWARE (fc1) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2015 by Cisco Systems, Inc. Compiled Thu 19-Feb-15 09:33 by prod_rel_team Initializing flashfs... FLASH CHIP: Spansion S25FL256 flashfs[2]: 11 files, 2 directories flashfs[2]: 0 orphaned files, 0 orphaned directories flashfs[2]: Total bytes: 31808000 flashfs[2]: Bytes used: 5918208 flashfs[2]: Bytes available: 25889792 flashfs[2]: flashfs fsck took 10 seconds. flashfs[2]: Initialization complete. flashfs[3]: 0 files, 1 directories flashfs[3]: 0 orphaned files, 0 orphaned directories flashfs[3]: Total bytes: 11999232 flashfs[3]: Bytes used: 1024 flashfs[3]: Bytes available: 11998208 flashfs[3]: flashfs fsck took 0 seconds. flashfs[3]: Initialization complete....done Initializing flashfs. This product contains cryptographic features and is subject to United States and local country laws governing import, export, transfer and use. Delivery of Cisco cryptographic products does not imply third-party authority to import, export, distribute or use encryption. Importers, exporters, distributors and users are responsible for compliance with U.S. and local country laws. By using this product you agree to comply with applicable laws and regulations. If you are unable to comply with U.S. and local laws, return this product immediately. A summary of U.S. laws governing Cisco cryptographic products may be found at: http://www.cisco.com/wwl/export/crypto/tool/stqrg.html If you require further assistance please contact us by sending email to export@cisco.com. cisco AIR-CAP1602I-A-K9 (PowerPC) processor (revision B0) with 187382K/74672K bytes of memory. Processor board ID FCW1929N2RT PowerPC CPU at 533Mhz, revision number 0x2151 Last reset from power-on LWAPP image version 8.0.115.0 1 Gigabit Ethernet interface 32K bytes of flash-simulated non-volatile configuration memory. Base ethernet MAC Address: E8:65:49:21:06:F0 Part Number : 73-14671-04 PCA Assembly Number : 000-00000-00 PCA Revision Number : PCB Serial Number : FOC192898H9 Top Assembly Part Number : 800-102028-03 Top Assembly Serial Number : FCW1929N2RT Top Revision Number : A0 Product/Model Number : AIR-CAP1602I-A-K9 % Please define a domain-name first. ipv6 enable ^ % Invalid input detected at '^' marker. ipv6 address autoconfig ^ % Invalid input detected at '^' marker. ipv6 address dhcp ^ % Invalid input detected at '^' marker. Press RETURN to get started! *Mar 1 00:00:12.683: APAVC: Initial WLAN Buffers Given to System is 500 *Mar 1 00:00:12.699: APAVC: WlanPAKs 9355 RadioPaks 8747 *Mar 1 00:00:13.343: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg *Mar 1 00:00:14.723: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state to up *Mar 1 00:00:15.639: %SYS-5-RESTART: System restarted -- Cisco IOS Software, C1600 Software (AP1G2-RCVK9W8-M), Version 15.3(3)JA3, RELEASE SOFTWARE (fc1) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2015 by Cisco Systems, Inc. Compiled Thu 19-Feb-15 09:33 by prod_rel_team *Mar 1 00:00:15.675: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg *Mar 1 00:00:16.723: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up *Mar 1 00:00:18.215: %SSH-5-ENABLED: SSH 2.0 has been enabledlwapp_crypto_init: MIC Present and Parsed Successfully APe865.4921.06f0> *Mar 1 00:00:27.655: %LINK-6-UPDOWN: Interface BVI1, changed state to down *Mar 1 00:00:28.655: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to down%Default route without gateway, if not a point-to-point interface, may impact performance *Mar 1 00:00:34.383: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg %Error opening flash:/capwap-saved-config (No such file or directory)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-29-2017 10:43 AM
Rasika
