Go join a capwap controller
Hello
*Jan 10 13:21:00.311: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Jan 10 13:21:00.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.1.1.                                            149 peer_port: 5246
*Jan 10 13:21:00.415: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip:                                             10.1.1.149 peer_port: 5246
*Jan 10 13:21:00.415: %CAPWAP-5-SENDJOIN: sending Join Request to 10.1.1.149
*Jan 10 13:21:00.415: %CAPWAP-3-ERRORLOG: Invalid event 10 & state 5 combination.
*Jan 10 13:21:00.415: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message typ                                            e 10 state 5.
*Jan 10 13:21:00.415: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from con                                            troller
*Jan 10 13:21:00.415: %CAPWAP-3-ERRORLOG: Failed to process encrypted capwap packet from 1                                            0.1.1.149
*Jan 10 13:21:18.655: %CAPWAP-3-ERRORLOG: Retransmission count for packet exceeded max(UNK
., 1)MESSAGE_TYPE (5)
*Jan 10 13:21:18.655: %CAPWAP-3-ERRORLOG: GOING BACK TO DISCOVER MODE
*Jan 10 13:21:18.655: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.1.1.149:52                                            46
*Jan 10 13:21:18.759: slave radio 2 dependancy on radio 1: force to DOWN state
*Jan 10 13:21:18.763: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
*Jan 10 13:21:18.779: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administrat                                            ively down
*Jan 10 13:21:18.779: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to administrat                                            ively down
*Jan 10 13:21:18.779: %LINK-5-CHANGED: Interface Dot11Radio2, changed state to administrat                                            ively down
*Jan 10 13:21:18.791: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Jan 10 13:21:18.795: slave radio 2 dependancy on radio 1: force to UP state
I have AIR-CAP3602I-A-K9
Cisco IOS Software, C3600 Software (AP3G2-K9W8-M), Version 15.2(4)JA1, RELEASE SOFTWARE (f                                            c2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Tue 30-Jul-13 22:57 by prod_rel_team
ROM: Bootstrap program is C3600 boot loader
BOOTLDR: C3600 Boot Loader (AP3G2-BOOT-M) LoaderVersion 12.4(23c)JY, RELEASE SOFTWARE (fc1                                            )
MY WLC is model 2504 version 7.5.102.0
10 Replies 10
Can you help me to solve my problem. the controller does not reach the AP
Is the ap and the WLC on the same vlan?  How many AP's have joined the WLC?  Can you post the show inventory from the WLC?  You should also upgrade to a better vice version like 7.6.130.0 and also upgrade the FUS to 1.9.0.0.  The version you are on is deferred.
-Scott
-Scott
I HAVE 12 AP. but currently I connected for testing.
Switch between WLC and I had a trunk. PA are in VLan 1 in the Switch
Put the ap and WLC management in the same vlan and try more than one AP.
-Scott
-Scott
if  activate the debug lwapp client event of the AP I have result:
*Jan 11 09:33:20.347: LWAPP_CLIENT_EVENT: spamResolveStaticGateway  - gateway found
*Jan 11 09:33:20.347: LWAPP_CLIENT_EVENT: Dropping discovery in LWAPP. This AP model is not supported by LWAPP WLC.
Well your log shows that the WLC code doesn't support the AP model.
Like I mentioned earlier, upgrade to v7.6.130.0 and FUS 1.9.0.0 as v7.5 is horrible.
-Scott
-Scott
Freerk Terpstra
Level 11
Level 11
Please post the following output:
1.  WLC:  sh sysinfo;
2.  WLC:  sh time;
3.  AP:  sh version;
4.  AP:  sh inventory
AP1>en
Password:
AP1#sh ver
Cisco IOS Software, C3600 Software (AP3G2-K9W8-M), Version 15.2(4)JA1, RELEASE SOFTWARE (fc2)
BOOTLDR: C3600 Boot Loader (AP3G2-BOOT-M) LoaderVersion 12.4(23c)JY, RELEASE SOFTWARE (fc1)
APe4c7.22b2.b0a8 uptime is 1 minute
System image file is "flash:/ap3g2-k9w8-mx.152-4.JA1/ap3g2-k9w8-xx.152-4.JA1"
Last reload reason:
 --More--  (196.200.80.24)
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco AIR-CAP3602I-A-K9 (PowerPC) processor (revision A0) with 180214K/81920K bytes of memory.
Processor board ID FTX1748R15A
PowerPC CPU at 800Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 7.5.102.0
1 Gigabit Ethernet interface
3 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Part Number                          : 73-14521-02
PCA Assembly Number                  : 800-37501-02
PCA Revision Number                  : A0
Top Assembly Part Number             : 800-35852-02
Top Assembly Serial Number           : FTX1748R15A
Top Revision Number                  : C0
Product/Model Number                 : AIR-CAP3602I-A-K9
Configuration register is 0xF
AP1#sh inventory
NAME: "AP3600", DESCR: "Cisco Aironet 3600 Series (IEEE 802.11n) Access Point"
PID: AIR-CAP3602I-A-K9 , VID: V01, SN: FTX1748R15A
NAME: "Dot11Radio2", DESCR: "802.11AC 5GHz Radio"
PID: AIR-RM3000AC-A-K9 , VID: 1  ,
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.5.102.0
Bootloader Version............................... 1.0.18
Field Recovery Image Version..................... 1.0.0
Firmware Version................................. PIC 16.0
Build Type....................................... DATA + WPS
System Name...................................... WIRELESS
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1279
IP Address....................................... 10.1.1.149
Last Reset....................................... Power on reset
System Up Time................................... 0 days 0 hrs 3 mins 8 secs
System Timezone Location.........................
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
--More-- or (q)uit
Configured Country............................... FR  - France
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +26 C
External Temperature............................. +31 C
Fan Status....................................... 4300 rpm
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 1
Number of Active Clients......................... 0
Maximum number of APs supported.................. 25
(Cisco Controller) >show time
Time............................................. Sat Jan  11 00:09:15 2015
Timezone delta................................... 0:0
Timezone location................................
NTP Servers
    NTP Polling Interval.........................     86400
     Index     NTP Key Index                  NTP Server                  NTP Msg Auth Status
You have an America country code access point and your WLC country code is set to France. You need to add US to the WLC country code or add US and remove FR if you don't have plans to locate access points in France. It's important to purchase the proper  access point for that country.
-Scott
-Scott
