GPRS/GSM Signal Booster
RichardgpBain
Can anyone recommend a GPRS/GSM signal booster solution? I am looking to boost the GPRS/GSM signal in a sports hall to help service chip n pin transactions.
I have looked into getting analogue lines installed and other alternatives but this seems to be the only method of processing the transactions.
I am looking to put an antenna on the roof and fit an access point inside the building, connected via coax.
Any suggestions on vendor/device?
0 Replies 0
