Guest access the management interface and guest anchor.
daswann
While reviewing our organizations WLC.s for best practice I notices that some of our sites have the guest SSID mapped to the management interface. Per the 8.5 config guide - Do not map a guest WLAN to the management interface. If the EoIP tunnel breaks, the client could obtain an IP and be placed on the management subnet. We are using guest anchor for these sites and they terminate on a different interface not management on the anchor WLC.
In this scenario are we still at risk to the above issue mentioned in the 8.5 config guide?
Thanks in advance
daswann
I just ran across this, anyone have thoughts on this for resolution to my question above:
The default interface used by the foreign WLC for the guest WLAN is the management interface. If the EoIP tunnel cannot be established with the anchor, the foreign controller will disassociate any wireless clients that were previously associated with the unreachable anchor and then assign new clients and reassociate clients to the interface configured under the guest WLAN of the foreign itself. Therefore, it is recommended to link the guest WLAN on the foreign to a non-routable network, or alternatively configure the DHCP server of the management interface with an unreachable IP address. If the anchor becomes unreachable, this prevents the guest clients to gain access to the management network.
Scott Fella
In the past when configuring guest anchor, I have always created a bogus interface like vlan666 or whatever and that doesn't reside in the trunk at all.  This way if the tunnel breaks, the traffic is placed on the vlan.  In my example, vlan666.
-Scott
Arshad Safrulla
On top of @Scott Fella's great advise, some generic design guidelines I use
  • disabling management over wireless
  • segregate guest wireless and wired subnets
  • disable DHCP on management Interface or configure an completely unreachable network as DHCP scope.
  • make use of CPU ACL to protect the WLC Management Access
  • use IP DHCP required option in the WLAN
Finally what ever the WLAN mode don't use management interface.
If you need more tips
https://www.ciscolive.com/c/dam/r/ciscolive/us/docs/2018/pdf/BRKEWN-2014.pdf
