guest anchor traffic flow isolation
habdelmageed
Visitor
Hi everyone
I have a guest SSID anchored to DMZ WLC and everything working fine with a customize guest solution, yet my client have his security concerns regarding the guest traffic that incase of any cyber attack our local network might be exposed or face a VLAN leaking, am looking for any documentation to confirm that the IP tunneling is secured and isolated from our local DC network, the traffic flow from the client to AP to foreign controller to DMZ controller is isolated and secured,
Many thanks for support in advance.
Mark Elsen
 - This is secure , as long as  the guest WLAN/VLAN is isolated from the Intranet as you are confirming ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Hi marce
Really appreciate your feedback
The issue that my client have a highly secured network with an air gaped guest environment and our CS team need a cisco documentation confirmation is there any document created by cisco to explain the anchor tunnel concept and isolation + port mapping for firewall rules for the traffic between DC zone & DMZ zone?
Thanks in advance.
Depend on the controller model you used (AireOS - traditional vs IOS-XE/9800 - modern) tunnel traffic port numbers may change. Otherwise same concept applicable for Guest Anchoring.  You can refer following deployment guide & FAQ
9800-Guest Anchoring
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/213912-configure-mobility-anchor-on-catalyst-98.html
AireOS Guest Anchor config guide
https://www.cisco.com/c/en/us/td/docs/wireless/controller/8-5/config-guide/b_cg85/configuring_auto_anchor_mobility.html
Guest Wi-Fi FAQ
https://www.cisco.com/c/en/us/support/docs/wireless/4400-series-wireless-lan-controllers/107458-wga-faq.html
Rasika
*** Pls rate all useful responses ***
