Guest Auth issue
ittechk4u1
Level 7
Level 7
Hello Experts,
I am using cisco mobility express AP"2802" as WLC.
Created a Guest wlan with custom webpage and authentication using radius server.
I can see that Clinet is getting authenticating in ise but client is getting error "The User name and password combination you have entered is invalid. "
Here are the debug logs:
(WLC1) >*emWeb: Mar 01 11:53:56.397: Authentication succeeded for - root on 10.18.20.9
*apfReceiveTask: Mar 01 11:54:07.855: ca:cb:31:95:a4:11 Received management frame ASSOCIATION REQUEST on BSSID cc:db:93:79:be:ae destination addr cc:db:93:79:be:ae slotid 1
*apfMsConnTask_0: Mar 01 11:54:07.856: ca:cb:31:95:a4:11 Updating the client capabiility as 4
*apfMsConnTask_0: Mar 01 11:54:07.856: ca:cb:31:95:a4:11 Processing assoc-req station:ca:cb:31:95:a4:11 AP:cc:db:93:79:be:a0-01 ssid : XYZGuest thread:5d6bdd20
*apfMsConnTask_0: Mar 01 11:54:07.856: ca:cb:31:95:a4:11 apfCreateMobileStationEntryWrapper (apf_ms.c:4510) Changing state for mobile ca:cb:31:95:a4:11 on AP cc:db:93:79:be:a0 from Idle to Idle
*apfMsConnTask_0: Mar 01 11:54:07.856: ca:cb:31:95:a4:11 Adding mobile on LWAPP AP cc:db:93:79:be:a0(1)
*apfMsConnTask_0: Mar 01 11:54:07.856: ca:cb:31:95:a4:11 Created Acct-Session-ID (603cc7cf/ca:cb:31:95:a4:11/26) for the mobile
*apfMsConnTask_0: Mar 01 11:54:07.856: ca:cb:31:95:a4:11 Setting hasApChnaged Flag as true. It is a fresh assoc request.
*apfMsConnTask_0: Mar 01 11:54:07.856: ca:cb:31:95:a4:11 req rcv on open Wlan
*apfMsConnTask_0: Mar 01 11:54:07.856: ca:cb:31:95:a4:11 Setting RTTS enabled to 0
*apfMsConnTask_0: Mar 01 11:54:07.856: ca:cb:31:95:a4:11 Association received from mobile on BSSID cc:db:93:79:be:ae AP AARAP001
*apfMsConnTask_0: Mar 01 11:54:07.856: ca:cb:31:95:a4:11 Station: CA:CB:31:95:A4:11 trying to join WLAN with RSSI -72. Checking for XOR roam conditions on AP: CC:DB:93:79:BE:A0 Slot: 1
*apfMsConnTask_0: Mar 01 11:54:07.856: ca:cb:31:95:a4:11 Station: CA:CB:31:95:A4:11 is associating to AP CC:DB:93:79:BE:A0 which is not XOR roam capable
*apfMsConnTask_0: Mar 01 11:54:07.856: ca:cb:31:95:a4:11 Global 200 Clients are allowed to AP radio
*apfMsConnTask_0: Mar 01 11:54:07.856: ca:cb:31:95:a4:11 Max Client Trap Threshold: 0 cur: 1
*apfMsConnTask_0: Mar 01 11:54:07.856: ca:cb:31:95:a4:11 Rf profile 600 Clients are allowed to AP wlan
*apfMsConnTask_0: Mar 01 11:54:07.856: ca:cb:31:95:a4:11 Updated local bridging VLAN to 0 while applying WLAN policy
*apfMsConnTask_0: Mar 01 11:54:07.856: ca:cb:31:95:a4:11 Updated session timeout to 0 and Sleep timeout to 720 while applying WLAN policy
*apfMsConnTask_0: Mar 01 11:54:07.856: ca:cb:31:95:a4:11 override for default ap group, marking intgrp NULL
*apfMsConnTask_0: Mar 01 11:54:07.856: ca:cb:31:95:a4:11 Applying Interface(management) policy on Mobile, role Unassociated. Ms NAC State 0 Quarantine Vlan 0 Access Vlan 0
*apfMsConnTask_0: Mar 01 11:54:07.856: ca:cb:31:95:a4:11 Not re-applying interface policy for local switching Client
*apfMsConnTask_0: Mar 01 11:54:07.856: ca:cb:31:95:a4:11 After applying Interface(management) policy on Mobile, role Unassociated. Ms NAC State 2 Quarantine Vlan 0 Access Vlan 0
*apfMsConnTask_0: Mar 01 11:54:07.856: ca:cb:31:95:a4:11 0.0.0.0 START (0) Changing IPv4 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:3486)
*apfMsConnTask_0: Mar 01 11:54:07.856: ca:cb:31:95:a4:11 0.0.0.0 START (0) Changing Url ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255),Default action is '0' --- (caller apf_policy.c:3506)
*apfMsConnTask_0: Mar 01 11:54:07.856: ca:cb:31:95:a4:11 0.0.0.0 START (0) Changing IPv6 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:3527)
*apfMsConnTask_0: Mar 01 11:54:07.857: ca:cb:31:95:a4:11 Values before applying NASID - interfacetype:0, ovrd:0, mscb nasid:, interface nasid:, APgrpset:0
*apfMsConnTask_0: Mar 01 11:54:07.857: ca:cb:31:95:a4:11 apfApplyWlanPolicy: Apply WLAN Policy over PMIPv6 Client Mobility Type, Tunnel User - 0
*apfMsConnTask_0: Mar 01 11:54:07.857: ca:cb:31:95:a4:11 Check before Setting the NAS Id to WLAN specific Id ''
*apfMsConnTask_0: Mar 01 11:54:07.857: ca:cb:31:95:a4:11 apf_policy.c:2771 Assigning the SGT 0 to mobile (earlier sgt 0)
*apfMsConnTask_0: Mar 01 11:54:07.857: ca:cb:31:95:a4:11 In processSsidIE:7640 setting Central switched to FALSE
*apfMsConnTask_0: Mar 01 11:54:07.857: ca:cb:31:95:a4:11 Disabling flexconnect central association for the client
*apfMsConnTask_0: Mar 01 11:54:07.857: ca:cb:31:95:a4:11 Applying site-specific Local Bridging override for station ca:cb:31:95:a4:11 - vapId 2, site 'default-group', interface 'management'
*apfMsConnTask_0: Mar 01 11:54:07.857: ca:cb:31:95:a4:11 Applying Local Bridging Interface Policy for station ca:cb:31:95:a4:11 - vlan 0, interface id 0, interface 'management', nasId:''
*apfMsConnTask_0: Mar 01 11:54:07.857: ca:cb:31:95:a4:11 Set Client Non AP specific WLAN apfMsAccessVlan = 172
*apfMsConnTask_0: Mar 01 11:54:07.857: ca:cb:31:95:a4:11 This apfMsAccessVlan may be changed later from AAA after L2 Auth
*apfMsConnTask_0: Mar 01 11:54:07.857: ca:cb:31:95:a4:11 Cleared localSwitchingVlan, may be assigned later based on AAA override
*apfMsConnTask_0: Mar 01 11:54:07.857: ca:cb:31:95:a4:11 processSsidIE statusCode is 0 and status is 0
*apfMsConnTask_0: Mar 01 11:54:07.857: ca:cb:31:95:a4:11 processSsidIE ssid_done_flag is 0 finish_flag is 0
*apfMsConnTask_0: Mar 01 11:54:07.857: ca:cb:31:95:a4:11 STA - rates (8): 140 18 152 36 176 72 96 108 0 0 0 0 0 0 0 0
*apfMsConnTask_0: Mar 01 11:54:07.857: ca:cb:31:95:a4:11 suppRates statusCode is 0 and gotSuppRatesElement is 1
*apfMsConnTask_0: Mar 01 11:54:07.857: ca:cb:31:95:a4:11 Assigning flex webauth IPv4-ACL ID :65535, IPv6-ACL ID:65535 for AP WLAN ID : 2
*apfMsConnTask_0: Mar 01 11:54:07.857: ca:cb:31:95:a4:11 Assigned flex post-auth IPv4-ACL ID :65535, IPv6-ACL ID:65535 for AP WLAN ID : 2
*apfMsConnTask_0: Mar 01 11:54:07.857: ca:cb:31:95:a4:11 Updating AID for REAP AP Client cc:db:93:79:be:a0 - AID ===> 1
*apfMsConnTask_0: Mar 01 11:54:07.857: ca:cb:31:95:a4:11 Assoc Req BSSID cc:db:93:79:be:ae AP(AARAP001) slot 1 ssid (XYZGuest) Tmstmp 5632 AID 1 stCode 0/0 apChngd 0 oldAp 00:00:00:00:00:00
*apfMsConnTask_0: Mar 01 11:54:07.857: ca:cb:31:95:a4:11 0.0.0.0 START (0) Initializing policy
*apfMsConnTask_0: Mar 01 11:54:07.857: ca:cb:31:95:a4:11 0.0.0.0 START (0) Change state to AUTHCHECK (2) last state START (0)
*apfMsConnTask_0: Mar 01 11:54:07.857: ca:cb:31:95:a4:11 apfVapSecurity=0x10 L2=0 SkipWeb=0
*apfMsConnTask_0: Mar 01 11:54:07.857: ca:cb:31:95:a4:11 AuthenticationRequired = 1
*apfMsConnTask_0: Mar 01 11:54:07.857: ca:cb:31:95:a4:11 0.0.0.0 AUTHCHECK (2) Change state to L2AUTHCOMPLETE (4) last state AUTHCHECK (2)
*apfMsConnTask_0: Mar 01 11:54:07.857: ca:cb:31:95:a4:11 Flex Central Auth Client
*apfMsConnTask_0: Mar 01 11:54:07.857: ca:cb:31:95:a4:11 0.0.0.0 L2AUTHCOMPLETE (4) DHCP required on AP cc:db:93:79:be:a0 vapId 2 apVapId 2for this client
*apfMsConnTask_0: Mar 01 11:54:07.857: ca:cb:31:95:a4:11 Not Using WMM Compliance code qosCap 00
*apfMsConnTask_0: Mar 01 11:54:07.857: ca:cb:31:95:a4:11 flex webauth acl id to be sent :65535 name : client acl id :65535 name :
*apfMsConnTask_0: Mar 01 11:54:07.857: ca:cb:31:95:a4:11 flex webauth ipv6 acl id to be sent :65535 name : client acl id :65535 name :
*apfMsConnTask_0: Mar 01 11:54:07.857: ca:cb:31:95:a4:11 Vlan while overriding the policy = -1
*apfMsConnTask_0: Mar 01 11:54:07.857: ca:cb:31:95:a4:11 sending to spamAddMobile vlanId -1 aclName = , flexAclId 65535
*apfMsConnTask_0: Mar 01 11:54:07.857: ca:cb:31:95:a4:11 0.0.0.0 L2AUTHCOMPLETE (4) Plumbed mobile LWAPP rule on AP cc:db:93:79:be:a0 vapId 2 apVapId 2 flex acl-name: v6acl-name
*apfMsConnTask_0: Mar 01 11:54:07.857: ca:cb:31:95:a4:11 0.0.0.0 L2AUTHCOMPLETE (4) Change state to DHCP_REQD (7) last state L2AUTHCOMPLETE (4)
*apfMsConnTask_0: Mar 01 11:54:07.857: ca:cb:31:95:a4:11 0.0.0.0 DHCP_REQD (7) pemApfAddMobileStation2 4276, Adding TMP rule
*apfMsConnTask_0: Mar 01 11:54:07.857: ca:cb:31:95:a4:11 Mobility peer ip is 0, failed to get session type
*apfMsConnTask_0: Mar 01 11:54:07.857: ca:cb:31:95:a4:11 0.0.0.0 DHCP_REQD (7) Adding Fast Path rule
type = Airespace AP - Learn IP address
on AP cc:db:93:79:be:a0, slot 1, interface = 1, QOS = 2
IPv4 ACL ID = 255, IPv
*apfMsConnTask_0: Mar 01 11:54:07.857: ca:cb:31:95:a4:11 0.0.0.0 DHCP_REQD (7) Fast Path rule (contd...) 802.1P = 0, DSCP = 46, TokenID = 1706, IntfId = 0 Local Bridging Vlan = 0, Local Bridging intf id = 0
*apfMsConnTask_0: Mar 01 11:54:07.857: ca:cb:31:95:a4:11 0.0.0.0 DHCP_REQD (7) Fast Path rule (contd...) AVC Ratelimit: AppID = 0 ,AppAction = 0, AppToken = 1706 AverageRate = 0, BurstRate = 0
*apfMsConnTask_0: Mar 01 11:54:07.858: ca:cb:31:95:a4:11 0.0.0.0 DHCP_REQD (7) Successfully plumbed mobile rule (IPv4 ACL ID 255, IPv6 ACL ID 255, L2 ACL ID 255,URL ACL ID 255,URL ACL Action 0)
*apfMsConnTask_0: Mar 01 11:54:07.858: ca:cb:31:95:a4:11 Updating info change db with CMX bitmap 0x0000
*apfMsConnTask_0: Mar 01 11:54:07.858: ca:cb:31:95:a4:11 apfMsAssoStateInc
*apfMsConnTask_0: Mar 01 11:54:07.858: ca:cb:31:95:a4:11 apfPemAddUser2 (apf_policy.c:465) Changing state for mobile ca:cb:31:95:a4:11 on AP cc:db:93:79:be:a0 from Idle to Associated
*apfMsConnTask_0: Mar 01 11:54:07.861: ca:cb:31:95:a4:11 apfPemAddUser2:session timeout forstation ca:cb:31:95:a4:11 - Session Tout 0, apfMsTimeOut '0' and sessionTimerRunning flag is 0
*apfMsConnTask_0: Mar 01 11:54:07.861: ca:cb:31:95:a4:11 Stopping deletion of Mobile Station: (callerId: 48)
*apfMsConnTask_0: Mar 01 11:54:07.861: ca:cb:31:95:a4:11 Func: apfPemAddUser2, Ms Timeout = 0, Session Timeout = 0
*apfMsConnTask_0: Mar 01 11:54:07.861: ca:cb:31:95:a4:11 Sending assoc-resp with status 0 station:ca:cb:31:95:a4:11 AP:cc:db:93:79:be:a0-01 on apVapId 2
*apfMsConnTask_0: Mar 01 11:54:07.861: ca:cb:31:95:a4:11 VHT Operation IE: width 80/1 ch 64 freq0 58 freq1 0 msc0 0xff msc1 0xff
*apfMsConnTask_0: Mar 01 11:54:07.861: ca:cb:31:95:a4:11 Sending Assoc Response (status: '0') to station on AP AARAP001 on BSSID cc:db:93:79:be:ae ApVapId 2 Slot 1, mobility role 0
*apfMsConnTask_0: Mar 01 11:54:07.861: ca:cb:31:95:a4:11 apfProcessAssocReq (apf_80211.c:12921) Changing state for mobile ca:cb:31:95:a4:11 on AP cc:db:93:79:be:a0 from Associated to Associated
*apfMsConnTask_0: Mar 01 11:54:07.861: ca:cb:31:95:a4:11 Mobility query, PEM State: DHCP_REQD
*apfMsConnTask_0: Mar 01 11:54:07.861: ca:cb:31:95:a4:11 0.0.0.0 DHCP_REQD (7) NO release MSCB
*apfMsConnTask_0: Mar 01 11:54:07.861: ca:cb:31:95:a4:11 Building Mobile Announce :
*apfMsConnTask_0: Mar 01 11:54:07.861: ca:cb:31:95:a4:11 Building Client Payload:
*apfMsConnTask_0: Mar 01 11:54:07.861: ca:cb:31:95:a4:11 Client Ip: 0.0.0.0
*apfMsConnTask_0: Mar 01 11:54:07.861: ca:cb:31:95:a4:11 Client Vlan Ip: 10.40.80.1, Vlan mask : 255.255.255.0
*apfMsConnTask_0: Mar 01 11:54:07.861: ca:cb:31:95:a4:11 Client Vap Security: 16
*apfMsConnTask_0: Mar 01 11:54:07.861: ca:cb:31:95:a4:11 Virtual Ip: 192.0.2.1
*apfMsConnTask_0: Mar 01 11:54:07.861: ca:cb:31:95:a4:11 ssid: XYZGuest
*apfMsConnTask_0: Mar 01 11:54:07.861: ca:cb:31:95:a4:11 Building Client profile name Payload:
*apfMsConnTask_0: Mar 01 11:54:07.861: ca:cb:31:95:a4:11 Profile Name: XYZGuest
*apfMsConnTask_0: Mar 01 11:54:07.861: ca:cb:31:95:a4:11 Building VlanIpPayload.
*pemReceiveTask: Mar 01 11:54:07.862: ca:cb:31:95:a4:11 0.0.0.0 Added NPU entry of type 9, dtlFlags 0x0
*spamApTask0: Mar 01 11:54:07.862: ca:cb:31:95:a4:11 Add SGT:0 to AP cc:db:93:79:be:a0
*spamApTask0: Mar 01 11:54:07.862: ca:cb:31:95:a4:11 Add CTS mobile SGT - Encoded the capwap payload for the mobile with SGT 0
*spamApTask0: Mar 01 11:54:07.862: ca:cb:31:95:a4:11 MS IP NULL during AddMobile, not sending IP Distribution
*spamApTask0: Mar 01 11:54:07.862: ca:cb:31:95:a4:11 Flex Ipv6 pre-auth acl is not present, not Encoding Flex Ipv6 acl for add mobile Payload
*spamApTask0: Mar 01 11:54:07.862: ca:cb:31:95:a4:11 Flex Ipv6 post auth acl is not present, not updating add mobile Payload
*spamApTask0: Mar 01 11:54:07.862: ca:cb:31:95:a4:11 Successful transmission of LWAPP Add-Mobile to AP cc:db:93:79:be:a0 slotId 1 idx@94
*spamApTask0: Mar 01 11:54:07.862: ca:cb:31:95:a4:11 Setting ADD_MOBILE (idx 95, action 0, last count 0) ack state for STA on AP cc:db:93:79:be:a0
*apfReceiveTask: Mar 01 11:54:07.864: ca:cb:31:95:a4:11 0.0.0.0 DHCP_REQD (7) mobility role update request from Unassociated to Local
Peer = 0.0.0.0, Old Anchor = 0.0.0.0, New Anchor = 10.40.80.1
*apfReceiveTask: Mar 01 11:54:07.864: ca:cb:31:95:a4:11 Created Cisco-Audit-Session-ID for the mobile: 0150280a0000000dcfc73c60 type: local
*apfReceiveTask: Mar 01 11:54:07.864: ca:cb:31:95:a4:11 Audit session id is created 0150280a0000000dcfc73c60 for mobility complete
*apfReceiveTask: Mar 01 11:54:07.864: ca:cb:31:95:a4:11 pemAdvanceState2 (pem_api.c:6869) Changing state for mobile ca:cb:31:95:a4:11 on AP cc:db:93:79:be:a0 from Associated to Associated
*apfReceiveTask: Mar 01 11:54:07.864: ca:cb:31:95:a4:11 0.0.0.0 DHCP_REQD (7) State Update from Mobility-Incomplete to Mobility-Complete, mobility role=Local, client state=APF_MS_STATE_ASSOCIATED
*apfReceiveTask: Mar 01 11:54:07.864: ca:cb:31:95:a4:11 0.0.0.0 DHCP_REQD (7) pemAdvanceState2 7003, Adding TMP rule
*apfReceiveTask: Mar 01 11:54:07.864: ca:cb:31:95:a4:11 Mobility peer ip is 0, failed to get session type
*apfReceiveTask: Mar 01 11:54:07.864: ca:cb:31:95:a4:11 0.0.0.0 DHCP_REQD (7) Replacing Fast Path rule
IPv4 ACL ID = 255,
*apfReceiveTask: Mar 01 11:54:07.864: ca:cb:31:95:a4:11 0.0.0.0 DHCP_REQD (7) Fast Path rule (contd...) 802.1P = 0, DSCP = 46, TokenID = 1706, IntfId = 0 Local Bridging Vlan = 0, Local Bridging intf id = 0
*apfReceiveTask: Mar 01 11:54:07.864: ca:cb:31:95:a4:11 0.0.0.0 DHCP_REQD (7) Fast Path rule (contd...) AVC Ratelimit: AppID = 0 ,AppAction = 0, AppToken = 1706 AverageRate = 0, BurstRate = 0
*apfReceiveTask: Mar 01 11:54:07.864: ca:cb:31:95:a4:11 0.0.0.0 DHCP_REQD (7) Successfully plumbed mobile rule (IPv4 ACL ID 255, IPv6 ACL ID 255, L2 ACL ID 255,URL ACL ID 255,URL ACL Action 0)
*apfReceiveTask: Mar 01 11:54:07.864: ca:cb:31:95:a4:11 Updating info change db with CMX bitmap 0x0000
*apfReceiveTask: Mar 01 11:54:07.864: ca:cb:31:95:a4:11 0.0.0.0 DHCP_REQD (7) NO release MSCB
*pemReceiveTask: Mar 01 11:54:07.864: ca:cb:31:95:a4:11 0.0.0.0 Added NPU entry of type 9, dtlFlags 0x0
*apfReceiveTask: Mar 01 11:54:07.866: ca:cb:31:95:a4:11 Received management frame ACTION on BSSID cc:db:93:79:be:ae destination addr cc:db:93:79:be:ae slotid 1
*apfMsConnTask_0: Mar 01 11:54:07.866: ca:cb:31:95:a4:11 Got action frame from the client (ActionCategory:5), payloadLen:17
*apfMsConnTask_0: Mar 01 11:54:07.866: ca:cb:31:95:a4:11 Found RM action category code
*apfMsConnTask_0: Mar 01 11:54:07.866: ca:cb:31:95:a4:11 Station: CA:CB:31:95:A4:11 sent 802.11K neighbor request to AP CC:DB:93:79:BE:A0
*apfMsConnTask_0: Mar 01 11:54:07.866: ca:cb:31:95:a4:11 Station: CA:CB:31:95:A4:11 requested neighbors on non XOR roam capable AP CC:DB:93:79:BE:A0 Slot 1
*apfReceiveTask: Mar 01 11:54:08.091: ca:cb:31:95:a4:11 WcdbClientUpdate: IP Binding from WCDB ip_learn_type 1, add_or_delete 1
*apfReceiveTask: Mar 01 11:54:08.091: ca:cb:31:95:a4:11 IPv4 Addr: 0:0:0:0
*CAPWAP DATA: Mar 01 11:54:08.091: ca:cb:31:95:a4:11 IAPP-IP-UPDATE(0):891 Bytes received for client
*apfReceiveTask: Mar 01 11:54:08.091: ca:cb:31:95:a4:11 Recieved MS IPv4 Addr= 172.28.40.233
*apfReceiveTask: Mar 01 11:54:08.091: ca:cb:31:95:a4:11 Not updating IPv4 Addr, as client is not in RUN state
*apfReceiveTask: Mar 01 11:54:08.091: ca:cb:31:95:a4:11 Recieved IPv6 addresses count: 1
*apfReceiveTask: Mar 01 11:54:08.091: ca:cb:31:95:a4:11 Updating MS IPv6[1] Addr= fe80:0000:0000:0000:c8cb:31ff:fe95:a411
*apfReceiveTask: Mar 01 11:54:08.091: ca:cb:31:95:a4:11 IPv4 Addr: 172:28:40:233
*apfReceiveTask: Mar 01 11:54:08.092: IP Context distribution - event: (DHCP IP LEARN) msCount: 1 ToAllAps: 1
*apfReceiveTask: Mar 01 11:54:08.092: ca:cb:31:95:a4:11 IP context distribution applicable for LSW, dhcp_reqd enabled wlans not sending for WLAN: 2
*apfReceiveTask: Mar 01 11:54:08.092: ca:cb:31:95:a4:11 dtlArpInsert: Add ARP entry IP 172.28.40.233, MAC ca:cb:31:95:a4:11, VLAN 0, INTF 1, Type 0, New 1 (caller apf_foreignap.c:1186)
,arp count = 1
*apfReceiveTask: Mar 01 11:54:08.092: ca:cb:31:95:a4:11 dtlArpSetType: Changing ARP Type from 0 ---> 1 for station ca:cb:31:95:a4:11
*apfReceiveTask: Mar 01 11:54:08.092: ca:cb:31:95:a4:11 172.28.40.233 DHCP_REQD (7) Change state to WEBAUTH_REQD (8) last state DHCP_REQD (7)
*apfReceiveTask: Mar 01 11:54:08.092: ca:cb:31:95:a4:11 172.28.40.233 WEBAUTH_REQD (8) pemAdvanceState2 7845, Adding TMP rule
*apfReceiveTask: Mar 01 11:54:08.092: ca:cb:31:95:a4:11 Mobility peer ip is 0, failed to get session type
*apfReceiveTask: Mar 01 11:54:08.092: ca:cb:31:95:a4:11 172.28.40.233 WEBAUTH_REQD (8) Replacing Fast Path rule
type = Airespace AP Client - ACL passthru
IPv4 AC
*apfReceiveTask: Mar 01 11:54:08.092: ca:cb:31:95:a4:11 172.28.40.233 WEBAUTH_REQD (8) Fast Path rule (contd...) 802.1P = 0, DSCP = 46, TokenID = 1706, IntfId = 0 Local Bridging Vlan = 0, Local Bridging intf id = 0
*apfReceiveTask: Mar 01 11:54:08.092: ca:cb:31:95:a4:11 172.28.40.233 WEBAUTH_REQD (8) Fast Path rule (contd...) AVC Ratelimit: AppID = 0 ,AppAction = 0, AppToken = 1706 AverageRate = 0, BurstRate = 0
*apfReceiveTask: Mar 01 11:54:08.092: ca:cb:31:95:a4:11 172.28.40.233 WEBAUTH_REQD (8) Successfully plumbed mobile rule (IPv4 ACL ID 255, IPv6 ACL ID 255, L2 ACL ID 255,URL ACL ID 255,URL ACL Action 0)
*apfReceiveTask: Mar 01 11:54:08.092: ca:cb:31:95:a4:11 Updating info change db with CMX bitmap 0x0000
*apfReceiveTask: Mar 01 11:54:08.092: ca:cb:31:95:a4:11 Plumbing web-auth redirect rule due to user logout
*apfReceiveTask: Mar 01 11:54:08.092: ca:cb:31:95:a4:11 172.28.40.233 WEBAUTH_REQD (8) NO release MSCB
*apfReceiveTask: Mar 01 11:54:08.092: ca:cb:31:95:a4:11 Assigning Address 172.28.40.233 to mobile
*apfReceiveTask: Mar 01 11:54:08.092: ca:cb:31:95:a4:11 DHCP success event for client. Clearing dhcp failure count for interface management.
*pemReceiveTask: Mar 01 11:54:08.092: ca:cb:31:95:a4:11 172.28.40.233 Added NPU entry of type 2, dtlFlags 0x0
*pemReceiveTask: Mar 01 11:54:08.092: ca:cb:31:95:a4:11 Pushing IPv6: fe80:0000:0000:0000:c8cb:31ff:fe95:a411 , intfId:0 and MAC: CA:CB:31:95:A4:11 , Binding to Data Plane. SUCCESS !!
*apfReceiveTask: Mar 01 11:54:08.134: ca:cb:31:95:a4:11 WcdbClientUpdate: IP Binding from WCDB ip_learn_type 2, add_or_delete 1
*apfReceiveTask: Mar 01 11:54:08.134: ca:cb:31:95:a4:11 IPv4 Addr: 172:28:40:233
*apfReceiveTask: Mar 01 11:54:08.134: ca:cb:31:95:a4:11 Subnet mismatches while registering IP address 172.28.40.233 with netmask 255.255.255.0 for client ca:cb:31:95:a4:11
*webauthRedirectME: Mar 01 11:54:08.962: ca:cb:31:95:a4:11 dtlArpFindMobile: ARP Lookup succeeded for 172.28.40.233 / ca:cb:31:95:a4:11
*webauthRedirectME: Mar 01 11:54:12.647: ca:cb:31:95:a4:11 dtlArpFindMobile: ARP Lookup succeeded for 172.28.40.233 / ca:cb:31:95:a4:11
*webauthRedirectME: Mar 01 11:54:12.738: ca:cb:31:95:a4:11 dtlArpFindMobile: ARP Lookup succeeded for 172.28.40.233 / ca:cb:31:95:a4:11
*webauthRedirectME: Mar 01 11:54:13.714: ca:cb:31:95:a4:11 dtlArpFindMobile: ARP Lookup succeeded for 172.28.40.233 / ca:cb:31:95:a4:11
*webauthRedirectME: Mar 01 11:54:13.733: ca:cb:31:95:a4:11 dtlArpFindMobile: ARP Lookup succeeded for 172.28.40.233 / ca:cb:31:95:a4:11
*emWeb: Mar 01 11:54:13.831: ca:cb:31:95:a4:11 dtlArpFindMobile: ARP Lookup succeeded for 172.28.40.233 / ca:cb:31:95:a4:11
*emWeb: Mar 01 11:54:13.903: ca:cb:31:95:a4:11 dtlArpFindMobile: ARP Lookup succeeded for 172.28.40.233 / ca:cb:31:95:a4:11
*emWeb: Mar 01 11:54:14.702: ca:cb:31:95:a4:11 dtlArpFindMobile: ARP Lookup succeeded for 172.28.40.233 / ca:cb:31:95:a4:11
*webauthRedirectME: Mar 01 11:54:14.907: ca:cb:31:95:a4:11 dtlArpFindMobile: ARP Lookup succeeded for 172.28.40.233 / ca:cb:31:95:a4:11
*webauthRedirectME: Mar 01 11:54:15.708: ca:cb:31:95:a4:11 dtlArpFindMobile: ARP Lookup succeeded for 172.28.40.233 / ca:cb:31:95:a4:11
*emWeb: Mar 01 11:54:36.406: ca:cb:31:95:a4:11 dtlArpFindMobile: ARP Lookup succeeded for 172.28.40.233 / ca:cb:31:95:a4:11
*ewmwebWebauth1: Mar 01 11:54:36.407: ca:cb:31:95:a4:11 Username entry (adef) created for mobile, length = 4
*ewmwebWebauth1: Mar 01 11:54:36.407: ca:cb:31:95:a4:11 Username entry (adef) created in mscb for mobile, length = 4
*aaaQueueReader: Mar 01 11:54:36.407: ca:cb:31:95:a4:11 Normal Response code for AAA Authentication : -9
*aaaQueueReader: Mar 01 11:54:36.407: ca:cb:31:95:a4:11 radiusServerFallbackPassiveStateUpdate: RADIUS server is not-ready 10.18.21.14 port 1812 index 0 active 0
*aaaQueueReader: Mar 01 11:54:36.407: ca:cb:31:95:a4:11 radiusServerFallbackPassiveStateUpdate: RADIUS server is not-ready 10.18.21.15 port 1812 index 1 active 1
*aaaQueueReader: Mar 01 11:54:36.407: ca:cb:31:95:a4:11 Found a server : 10.18.21.15 from the WLAN server list of radius server index 2
*aaaQueueReader: Mar 01 11:54:36.407: ca:cb:31:95:a4:11 Send Radius Auth Request with pktId:3 into qid:1 of server at index:1
*aaaQueueReader: Mar 01 11:54:36.407: ca:cb:31:95:a4:11 Sending the packet to v4 host 10.18.21.15:1812 of length 245
*aaaQueueReader: Mar 01 11:54:36.407: ca:cb:31:95:a4:11 Successful transmission of Authentication Packet (pktId 3) to 10.18.21.15:1812 from server queue 1, proxy state ca:cb:31:95:a4:11-00:00
*aaaQueueReader: Mar 01 11:54:36.407: ca:cb:31:95:a4:11 User entry not found in the Local FileDB for the client.
*radiusTransportThread: Mar 01 11:54:41.592: ca:cb:31:95:a4:11 Retransmit the 'Access-Request' (id 3) to 10.18.21.15 (port 1812, qid 1) reached for mobile. msg retx 1 srvr retx 0 srvr evt 2 srvr tried 0
*radiusTransportThread: Mar 01 11:54:41.592: ca:cb:31:95:a4:11 Sending the packet to v4 host 10.18.21.15:1812 of length 245
*radiusTransportThread: Mar 01 11:54:41.592: ca:cb:31:95:a4:11 Successful transmission of Authentication Packet (pktId 3) to 10.18.21.15:1812 from server queue 1, proxy state ca:cb:31:95:a4:11-00:00
*radiusTransportThread: Mar 01 11:54:46.799: ca:cb:31:95:a4:11 Retransmit the 'Access-Request' (id 3) to 10.18.21.15 (port 1812, qid 1) reached for mobile. msg retx 2 srvr retx 2 srvr evt 2 srvr tried 0
*radiusTransportThread: Mar 01 11:54:46.799: ca:cb:31:95:a4:11 Sending the packet to v4 host 10.18.21.15:1812 of length 245
*radiusTransportThread: Mar 01 11:54:46.799: ca:cb:31:95:a4:11 Successful transmission of Authentication Packet (pktId 3) to 10.18.21.15:1812 from server queue 1, proxy state ca:cb:31:95:a4:11-00:00
*radiusTransportThread: Mar 01 11:54:52.006: ca:cb:31:95:a4:11 Retransmit the 'Access-Request' (id 3) to 10.18.21.15 (port 1812, qid 1) reached for mobile. msg retx 3 srvr retx 5 srvr evt 2 srvr tried 0
*radiusTransportThread: Mar 01 11:54:52.006: ca:cb:31:95:a4:11 Sending the packet to v4 host 10.18.21.15:1812 of length 245
*radiusTransportThread: Mar 01 11:54:52.006: ca:cb:31:95:a4:11 Successful transmission of Authentication Packet (pktId 3) to 10.18.21.15:1812 from server queue 1, proxy state ca:cb:31:95:a4:11-00:00
*radiusTransportThread: Mar 01 11:54:53.608: Radius Passive Fallback - Auth server is not ready 10.18.21.15 port 1812
*radiusTransportThread: Mar 01 11:54:53.609: Radius Passive Fallback - Acct server is not ready 10.18.21.15 port 1813
*radiusTransportThread: Mar 01 11:54:53.609: ca:cb:31:95:a4:11 Error Response code for AAA Authentication : -5
*radiusTransportThread: Mar 01 11:54:53.609: ca:cb:31:95:a4:11 Normal Response code for AAA Authentication : -7
*radiusTransportThread: Mar 01 11:54:53.609: ca:cb:31:95:a4:11 Returning AAA Error 'No Server' (-7) for mobile ca:cb:31:95:a4:11 serverIdx 1
*ewmwebWebauth1: Mar 01 11:54:53.609: ca:cb:31:95:a4:11 Plumbing web-auth redirect rule due to user logout
*ewmwebWebauth1: Mar 01 11:54:53.609: ca:cb:31:95:a4:11 Web Authentication failure for station
*ewmwebWebauth1: Mar 01 11:54:53.609: ca:cb:31:95:a4:11 172.28.40.233 WEBAUTH_REQD (8) Reached ERROR: from line 7636
*ewmwebWebauth1: Mar 01 11:54:53.609: ca:cb:31:95:a4:11 Username entry 'adef' is deleted for mobile from the UserName table
*ewmwebWebauth1: Mar 01 11:54:53.609: ca:cb:31:95:a4:11 Username entry adef deleted for mobile
*emWeb: Mar 01 11:54:53.806: ca:cb:31:95:a4:11 dtlArpFindMobile: ARP Lookup succeeded for 172.28.40.233 / ca:cb:31:95:a4:11
*webauthRedirectME: Mar 01 11:54:54.813: ca:cb:31:95:a4:11 dtlArpFindMobile: ARP Lookup succeeded for 172.28.40.233 / ca:cb:31:95:a4:11
*webauthRedirectME: Mar 01 11:54:54.829: ca:cb:31:95:a4:11 dtlArpFindMobile: ARP Lookup succeeded for 172.28.40.233 / ca:cb:31:95:a4:11
*webauthRedirectME: Mar 01 11:54:54.879: ca:cb:31:95:a4:11 dtlArpFindMobile: ARP Lookup succeeded for 172.28.40.233 / ca:cb:31:95:a4:11
what could be the reason ?
Switch Port config where AP/WLC is connected:
interface GigabitEthernet3/0/43
switchport trunk native vlan 80
switchport trunk allowed vlan 80,92,172
switchport mode trunk
Info: Ping from WLC to both ISE server are working.
Thanks in advance
5 Accepted Solutions
Nicolas Poirier
Level 4
Level 4
According to the log, the first RADIUS request and the retransmission from the WLC received no answer fron the ISE Server.
I would check the RADIUS livelog on ISE to see if everything is fine (WLC added as a NAD, no RADIUS key mismatch, etc.).
Sandeep Choudhary
As per logs...ISE server are not responding back!
Please check the NAD config, share secret!!
Also let us know the software version you are running on Ap/WLC?
Dont forget to rate helpful posts
can you run these commands on WLC:
test aaa radius username <username> password <Password >wlan-id <wlan id>
then run  test aaa show radius
Also can you check if something is blocking (on firewall may be!!) in between ISE and WLC!!
Check if anything is blocking between ISE and WLC.
If nothing blocking then raise a TAC case or downgrade the Software of WLC and try again!
Dont forget to arte helpful posts
Like what Sandeep mentioned, looks like the connectivity for radius is being blocked or dropped. Here is a guide on the test to help clarify what the test commands do and how to read the output.
https://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/212473-verify-radius-server-connectivity-with-t.html
-Scott
9 Replies 9
Nicolas Poirier
Level 4
Level 4
Sandeep Choudhary
Thanks @Sandeep Choudhary @Nicolas Poirier
I check twice and can confirm that WLC already added as NAD and shared secret  is same on both device.
I am running cisco 8.10.142.0 version on AP/WLC.
Thanks for your help.
Hello Sandeep
Please the output of the commands:
(WLC1) >test aaa radius username guest1 password abcde12 wlan-id 3
Radius Test Request
Wlan-id........................................ 3
ApGroup Name................................... none
Attributes Values
User-Name guest1
Called-Station-Id 00-00-00-00-00-00:XYZGuest
Calling-Station-Id 00-11-22-33-44-55
Nas-Port 0x00000001 (1)
Nas-Ip-Address 192.68.80.1
NAS-Identifier WLC1
Airespace / WLAN-Identifier 0x00000002 (2)
User-Password abcde12
Service-Type 0x00000008 (8)
Framed-MTU 0x00000514 (1300)
Nas-Port-Type 0x00000013 (19)
Cisco / Audit-Session-Id 0150280a0000001b47f83c60
Acct-Session-Id 603cf847/00:11:22:33:44:55/35
(WLC1) >test aaa show radius
previous test command still not completed, try after some time
Radius Test Request
Radius Test Response
Radius Server Retry Status
xx.xx.21.xx 6 No response received from server
Authentication Response:
Result Code: No response received from server
No AVPs in Response
Thank you guys.
Finally issue got resolved after WLC/AP downgraded to 8.8.125.0 version.
Dont know why cisco have so bugy softwares.
Thanks again to all.
-Scott
Nicolas Poirier
Level 4
Level 4
Are you seeing logs on the ISE RADIUS Livelogs?
First thing to check is if the Access-Request is received by your ISE Server.
If the request was dropped by the ISE Server, you will have an explaination on the log.
If the Request was not received, I would checked routing and filtering between WLC and ISE.
If you don't find any log on ISE, you can perform a tcpdump from the ISE Server (Operations > Diagnostic Tools > TCP Dump) to verify that the RADIUS request from the WLC is received by the ISE Server.
