Guest https=disabled; Management https=enabled
sniff
Level 3
Level 3
Is it possible to enable https globaly but disable https for guest-user access, only (no certificate security message)?
regards
Sven
weterry
Level 10
Level 10
Negative.
If you want HTTP for WebAuth, it must be globally disabled, which as you know takes out HTTPs for MGMT.
I'm not sure if there are any official product enhancement requests for this or not out there in the system....
I believe most people settle for this (or buy a valid webauth cert) and then juse SSH access and WCS......
weterry
Level 10
Level 10
Negative.
Thanks for your answer.
Sven
