Guest LAN authentication - WLC9800
eeebbunee
Hello Professional,
I would like to control Guest users who connects Guest network over the wired using WLC 9800.
VLAN 500 is Guest VLAN and currently it is matched with SSID/Policy 'Guest'.
All wireless guests are required to pass L3 authentication (Web) which controller provided.
Goal: When guest connects to wired connection (L2 switch) and port configured guest VLAN (500), then they needs to pass authentication.
In this case, can I use VLAN500 for wireless and wired both?
Between controller and L2 switch, there are two connections. One is trunk except VLAN500 and the other is VLAN500.
Should I also make the port to be 'Trunk except VLAN500' to L2's uplink port?
(* Uplink port = L2-Core switch connection)
Thank you for your time.
Firstly without an anchored WLC you will need to determine how you are going to restrict users from accessing the corporate network.
the deployment guide for this is here https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/16-12/config-guide/b_wl_16_12_cg/wired-guest.html
You authentication methods are basically going to be open or LWA
other option for this is to use NAC and have ISE provide the portal and access
*****Help out other by using the rating system and marking answered questions as "Answered"*****
