Guest Management CWA on C9800 with ISE
huseyin
Hi everyone,
I try to work with CWA on C9800. I installed a LAB scenario on my LAB.
ADA LAB Guest Management with ISE
Inverment;
Cisco C3850 PoE+ 24 Port 10G Uplink switch (Last version IOS)
Cisco C9800-CL Wireless Controller ver17.12.4
Cisco 1815iAP (Last Version IOS)
Cisco ISE v3.1
Active Directory Windows 2022 Standart Evaluation (Last Update)
Cisco ISE ESXi Host Configuration
Cisco C9800 ESXi Host Configuration
Lab Local Network Table;
VLAN Name
VLAN ID
VLAN Network
Subnet
Gateway ASA
ISE IP
Management
40
192.168.40.1-254
\24
192.168.40.254
192.168.40.236
BYOD
91
10.10.91.1-254
\24
10.10.91.254
10.10.91.236
Guest
\24
10.10.10.254
10.10.10.236
Inside
90
10.10.90.1-254
\24
10.10.90.254
10.10.90.236
Quarantina
\24
192.168.3.254
192.168.3.236
Server
100
192.168.100.1-254
\24
192.168.100.254
192.168.100.236
We are configuring all Interfaces on Cisco ISE. We target is to seperate beetwen networks. Forthis reason; we have more security and just different links to Access for Guest or BYOD. Also we can use for Quarantina Operations.
For ISE Guest Portals Settings are;
Guest
IP
Port
Hotspot
10.10.10.236
8999
Self-Register
10.10.10.236
8997
Sponsored
10.10.10.236
8998
Sponsor
10.10.90.236
8945
Topology is like below; Radius and web server is actually same device; Cisco ISE.
All ports and links are very successfuly working in their VLANs. If we are using Preshared Key (PSK) to join relevant VLAN everythings fine. We can Access to all link.
But we try to 802.1x its not work! I guess this problem is network problem but I did not resolve. When The 802.1x Access be active; redirection is work but the relevant link is not come. I am waiting for a lot of minutes. After that I need to reset my labtop network settings.
When I creat a  Configuration->Security->Web Auth in C9800 Web GUI; The device automatically creat 2 dfferent gorup ACL’s.
And Second ACL Group
And unfortunatelly There are not doing update.
Does anyone have any suggestions?
0 Replies 0
