11-29-2009 02:11 PM - edited 07-03-2021 06:18 PM
Do do you enable guest mode on a Cisco Wireless LAN controller (4404)?
Auto AP
dot11 ssid Test
vlan 111
authentication open
guest-mode
Guest mode
If you want the access point to allow associations from client devices that do not specify an SSID in their configurations, you can set up a guest SSID. The access point includes the guest SSID in its beacon. The access point's default SSID, tsunami, is set to guest mode. However, to keep your network secure, you should disable the guest mode SSID on most access points.
11-30-2009 07:42 AM
On the controller just edit your WLAN and check the broadcast SSID box on the general tab.
10-06-2010 03:14 AM
Unfortunately, broadcast SSID doesn't solve this problem .
If I set Set Single Guest Mode SSID on autonomous access point, then client with old and cheap adapters like ralonk rt61 can connect, but if I disable all WLAN but one with broadcast SSID on 2106 rt61 client still can connects only rarely.
So- is there analog of Set Single Guest Mode SSID in wlan controllers?
