Guest SSID possible to restrict access to a single web page?
Mottok
We have a guest SSID configured using MAB authentication with ISE (I am completely new to this as our network engineer has left, so this is about as much as I know!).
I've been asked to find out if we can restrict this SSID to allow it to only go to one specific website, is this possible and if so how can I do this?
Many thanks.
6 Replies 6
Sandeep Choudhary
you could apply an ACL to allow the ip address of the website and then deny everything else.
Dont forget to arte helpful posts
Many thanks for that. Would that be on the controller somewhere or at a firewall level? And I take it that would be at an IP address level rather than domain name? Sorry for the newbie questions, just learning. Thanks.
Are you using ISE for MAB authentication or ?
yes that will be filtered with IP address rahter then domain name!!
Dont forget to rate helpful posts
Hi, yes using ISE for MAB. SO I'm guessing I would do the ACL in ISE somewhere? Thanks.
you can create ACL in WLC or DACLin ISE and push it from ISE via AuthZ profiles.
Ok thanks, understand about 50% of what that means but gives me somewhere to start, many thanks for your help.
