adding another controller to system
osman.elhanafy
Level 4
Level 4
Dears,
if i need to add another controller-WLC to existing one in the network to achieve high availability.
is this need a downtime (restarting  the original controller) or not?
thanks
Scott Fella
N+1 doesn’t require a downtime. SSO does.
-Scott
thanks for your response.
Should the two controllers have the same software version ?
Recommandation is to keep the same software version on both WLC else when AP will move from primary to secondary then all AP need to download /install the new software from WLC and it will lead to dwontime of 5-10 minutes.
Dont forget to rate helpful posts
Sandeep Choudhary
additing to scott..
here are the guide to implement:
HA AP/Client SSO:
https://networkguy.de/?p=558
HA N+1 :
https://rscciew.wordpress.com/2014/06/07/n1-high-availability-configuration-on-cisco-2504wlc/
