Guest users authentication on WLC5508
Sindibade 78
Please I need to know if i can use WLC5508 as local AAA server for Guest WLAN users trought web portal
regards
Adil
Stephen Rodriguez
Yes, you can do this.  Under Security > Local Net Users, you need to add the usernames and passwords for the users that you want to allow to authenticate.
Cheers,
Steve
Please remember to rate helpful posts
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
hi,
i have create local user mapping to the guest ssid profile. i have enabled web policy with authentication for this ssid but when i connect to it i receive the dhcp param but i can't get the web authentication page i can see the header on the windows but the page still blank.
The same issue with passtrought mode.
The url seen requested is ip address of  wlc management interface configured as dns ip add on dhcp pool.
when i remove webpolicy i get access to internet.
please any idea about this usuee.
that's odd.  The web redirect should show the address of the virtual interface and not the management interface.
Can you post the show run-config from the WLC?
Cheers,
Steve
HTH,
Steve
