Guest WiFi
I have a campus that is interested in setting up a a guest SSID, but they would like the guest to enter their Name, phone and email so that they can keep track of these guest. Presently they use a RADIUS for the students, any suggestion is greatly appreciated.
joey.debra
Meraki Community All-Star
For this you will need to have your own portal page so you can capture these datafields separately. The only thing your portal page must to is send a specific command back to allow access to the network.
I hope this older document is still relevant:
https://meraki.cisco.com/lib/pdf/meraki_whitepaper_captive_portal.pdf
Else you can check out the Meraki marketplace to see if external partners have pre-cooked solutions to explore and perhaps purchase.
joey.debra
Ambuj M
if your radius is ISE or something equivalent, you can use centralised web auth with Guest portal, there is a lot of flexibility in customizing what information you can ask users before they can connect.
google Cisco ISE self service guest portal
-hope this helps-
Philip D'Ath
Splash Access is a very popular third-party splash page system with these capabilities.
https://www.splashaccess.com/
Thanks for all the recommendations!
