Guest Wired with Anchor WLC - No connectivity
We are using wired and Wireless guest access with an Anchor Controller installed in a DMZ. The Wireless guest access
works fine but it's not the case for the wired access. The client doesn't receive an IP address. A debug client x.x.x.x
shows :
*May 06 09:35:25.545: 00:18:8b:af:56:95 Adding mobile on Wired Guest 00:00:00:00:00:00(0)
*May 06 09:35:25.545: 00:18:8b:af:56:95 apfHandleWiredGuestMobileStation (apf_wired_guest.c:123) Changing state for mobile 00:18:8b:af:56:95 on AP 00:00:00:00:00:00 from Idle to Associated
*May 06 09:35:25.545: 00:18:8b:af:56:95 0.0.0.0 START (0) Initializing policy
*May 06 09:35:25.545: 00:18:8b:af:56:95 0.0.0.0 START (0) Change state to AUTHCHECK (2) last state AUTHCHECK (2)
*May 06 09:35:25.545: 00:18:8b:af:56:95 0.0.0.0 AUTHCHECK (2) Change state to L2AUTHCOMPLETE (4) last state L2AUTHCOMPLETE (4)
*May 06 09:35:25.545: 00:18:8b:af:56:95 0.0.0.0 L2AUTHCOMPLETE (4) Change state to DHCP_REQD (7) last state DHCP_REQD (7)
*May 06 09:35:25.545: 00:18:8b:af:56:95 apfPemAddUser2 (apf_policy.c:212) Changing state for mobile 00:18:8b:af:56:95 on AP 00:00:00:00:00:00 from Associated to Associated
*May 06 09:35:25.545: 00:18:8b:af:56:95 Stopping deletion of Mobile Station: (callerId: 48)
*May 06 09:35:25.546: 00:18:8b:af:56:95  Wired Guest packet from 10.56.53.254 on mobile
*May 06 09:35:25.546: 00:18:8b:af:56:95 Orphan Packet from 10.56.53.254
*May 06 09:35:27.044: 00:18:8b:af:56:95  Wired Guest packet from 10.56.53.254 on mobile
*May 06 09:35:27.044: 00:18:8b:af:56:95 Orphan Packet from 10.56.53.254
*May 06 09:35:27.434: 00:18:8b:af:56:95 0.0.0.0 DHCP_REQD (7) State Update from Mobility-Incomplete to Mobility-Complete, mobility role=ExpForeign, client state=APF_MS_STATE_ASSOCIATED
*May 06 09:35:27.434: 00:18:8b:af:56:95 Stopping deletion of Mobile Station: (callerId: 75)
*May 06 09:35:27.434: 00:18:8b:af:56:95 0.0.0.0 DHCP_REQD (7) Change state to RUN (20) last state RUN (20)
*May 06 09:35:27.436: 00:18:8b:af:56:95 0.0.0.0 RUN (20) Reached PLUMBFASTPATH: from line 4218
*May 06 09:35:27.436: 00:18:8b:af:56:95 0.0.0.0 RUN (20) Adding Fast Path rule
  type = Airespace AP Client
  on AP 00:00:00:00:00:00, slot 0, interface = 13, QOS = 0
  ACL Id = 255, Jumbo Frames = NO, 802.1
*May 06 09:35:27.436: 00:18:8b:af:56:95 0.0.0.0 RUN (20) Successfully plumbed mobile rule (ACL ID 255)
*May 06 09:35:27.436: 00:18:8b:af:56:95 Set bi-dir guest tunnel for 00:18:8b:af:56:95 as in Export Foreign role
*May 06 09:35:27.436: 00:18:8b:af:56:95 0.0.0.0 Added NPU entry of type 1, dtlFlags 0x4
*May 06 09:35:28.546: 00:18:8b:af:56:95 DHCP received op BOOTREQUEST (1) (len 323, port 13, encap 0xec06)
*May 06 09:35:28.546: 00:18:8b:af:56:95 DHCP dropping packet
*May 06 09:35:31.545: 00:18:8b:af:56:95 DHCP received op BOOTREQUEST (1) (len 323, port 13, encap 0xec06)
*May 06 09:35:31.545: 00:18:8b:af:56:95 DHCP dropping packet
The principal steps of the configuration were :
- Create a dynamic interface and mark it is as a "Guest LAN",
- Configure the mobility group of the Anchor Controller in the Remote Controller,
- Configure the mobility group of the Remote Controller in the Anchor Controller,
- Create the wired WLAN with the exact name in the Anchor WLC and the Remote WLC,
- The used interfaces are None (Ingress interface) and Management (Ergress interface) for the Anchor WLC,
- The used interfaces are Layer2 Guest Vlan (Ingress interface) and Management (Ergress interface) for the Remote WLC,
- Create the Mobility Anchor on the Anchor WLC and map it to itself,
- Create the Mobility Anchor on the Remote WLC and choose the IP address of the Anchor WLC,
- Data and Control Path are up in both devices.
Both WLC controllers use the same code.
Thank you.
0 Replies 0
