Guest Wireless Script ???
Alex Li
Hello All,
I have setup a guest wireless SSID on my 2504 WLC. I am trying to determine the best possible way to administer the Guest Wireless usernames and passwords. Is this possible ?
Does anyone know if its possible to run a script or command that could reset the Guest Wireless password daily and email to a lobby admin ?
or
Am I better off creating the user accounts as required basis ?
Colin
Scott Fella
I don't know if that easier or not to be honest.  If you require every user to have a separate account, then lobby admin is your answer.  Many times customers will have a generic username and password that they will change every so often and that helps with the burden on how many users you have to create.  Issue becomes if someone brings in like 30 guest compared to 1 or 2 per day.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Abhishek Abhishek
I would suggest to use lobby administrator for handling users rather than creating user accounts for each and every user.
For details of the lobby administrator configuration please refer to the link-
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a0080871921.shtml
