04-03-2014 02:22 PM - edited 07-05-2021 12:36 AM
I just put in a 5508 WLC with a pretty basic setup.
I have a Guest WLAN configured that uses authentication with the local user database on the controller.
When I connect to the wireless network, I get an IP address from DHCP and my wireless adapter looks good. However, when I attempt to connect to the Internet (or network for that matter), the authentication page doesn't appear. If I put https://1.1.1.1/login.html in my URL field in Firefox, I get the page and am able to enter in my credentials. After that, everything works perfectly.
We do not have an internal DNS server on this wireless network: I simply point users to 8.8.8.8
What causes this? Any way to correct?
Solved! Go to Solution.
04-04-2014 04:40 AM
why don;t you try setting up the guest with no security, then using this to make sure your routing and i particular your dns is configured correctly before adding web-auth back in again.
here is a helpful link.
http://www.cisco.com/c/en/us/support/docs/wireless/5500-series-wireless-controllers/108501-webauth-tshoot.html
Mike
04-04-2014 05:46 AM
Review this document:
Check your Web Authentication Proxy setting. If you are not using a proxy and it is disabled, what version code are you running and is IPv6 enabled or disabled globally?
04-04-2014 04:40 AM
Mike
04-06-2014 08:49 AM
Thanks guys: I just needed to tinker with the auto-proxy settings on my Mac --everything works fine now
04-04-2014 05:46 AM
04-06-2014 06:58 AM
enable tcp mss on wlc for APs and try
